I want to add an IR remote control to the 3pi.
I did not found one for the 3pi but for arduino.
There is also a doc describing how to make 3pi Arduino ready …
but I found in this doc "this library will conflict with any other libraries that
rely on or reconfigure Timer0 or Timer2"
So I wonder if there is the other way around possible …to migrate an arduino lib to
3pi?
Does someone have a recomandation for me?
Should I go the 3pi->Arduino way or migrate the lib to 3pi?
I think it will be easier to migrate it to the 3pi. That way you can consider everything it is depending on and make sure you are not making any assumptions.
thanks for the recommandation …
it was also my feeling and so I started my own IR receiver function …
…what I learnt meanwhile … AVR Studio does not support c++ very well
strange … which compiler does you use for the libs?
ok so I will try to use inherance for the inpulse lib to add the callback function
and make use of it for my sirc decoder and may be later for the QTRsensor.
