Still working at this. I tried changing build.core to simply arduino rather than arduino:arduino and now it doesn’t complain about needing arduino:arduino cores but it still fails on build.
Either changing build.core is causing the failure or it has exposed the underlying cause. I got the following error message which I did see before when it was complaining about arduino:arduino cores but didn’t think much of it.
I wonder if the code in this repo changed and this is why it all of the sudden caused a problem on my Mac even though, as mentioned, I didn’t change anything.
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x10 pc=0x1190c3c]
goroutine 1 [running]:
github.com/arduino/arduino-builder.(*SetupBuildProperties).Run(0x1860e50, 0xc420051000, 0x1860e50, 0x0)
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/setup_build_properties.go:98 +0x11bc
github.com/arduino/arduino-builder.(*ContainerSetupHardwareToolsLibsSketchAndProps).Run(0x1860e50, 0xc420051000, 0x1860e50, 0x0)
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/container_setup.go:63 +0x41d
github.com/arduino/arduino-builder.runCommands(0xc420051000, 0xc420061da0, 0x3, 0x3, 0xc420061d01, 0x10c0e95, 0xc42001f790)
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/builder.go:207 +0xe5
github.com/arduino/arduino-builder.(*ParseHardwareAndDumpBuildProperties).Run(0xc420061e00, 0xc420051000, 0x66, 0x7ffeefbffcbb)
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/builder.go:195 +0xee
github.com/arduino/arduino-builder.RunParseHardwareAndDumpBuildProperties(0xc420051000, 0x66, 0x7ffeefbffcbb)
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/builder.go:228 +0x35
main.main()
/home/jenkins/workspace/arduino-builder-all-cross/src/github.com/arduino/arduino-builder/arduino-builder/main.go:396 +0x96a
/Applications/Arduino.app/Contents/Java/arduino-builder returned 2
So it appears to be a segfault from trying to access an invalid memory location… but again, this might just be self induced by changing build.core from arduino:arduino to arduino
This is not really in my wheelhouse but I’ll keep trying until someone more intimate with this can help out.
EDIT:
(due to restrictions I can’t post more than 3 replies in a row
so I’m editing my last post to post the solution)
Okay, I figured out my problem. I’m not sure why this was complaining since I hadn’t changed anything but it appears the folder structure is not what the IDE is looking for. I downloaded the zip (same as cloning the repo) and placed it in the hardware folder as is.
To get this to work I had to create the structure of hardware–>libpololu–>avr and place the contents here… but that’s not all. This doesn’t allow the IDE to find the boards file so I had to move the contents of the arduino folder (currently hardware–>libpololu–>avr–>arduino) where the boards.txt file was and place the files directly in the hardware–>libpololu–>avr folder.
I figured this out by looking at the structure of another set of boards that require manual installation whose structure was slightly different than that of pololus.
P.S. I did change the build.core back to arduino:arduino so don’t mess with that, the only thing I needed to do was restructure the directories.
