I am trying to run code from arduino on baby o
basically it connects a wireless wiinunchuck with arduino I am not sure why it’s not working on baby o 328
here is the code (I am using the arduino ide to upload to the baby o)
// read out a Wii Nunchuck controller
// adapted to work with wireless Nunchuck controllers of third party vendors by Michael Dreher <michael@5dot1.de>
// adapt to your hardware config
#define POWER_VIA_PORT_C2_C3 1 // use port pins port C2 and C3 as power supply of the Nunchuck (direct plug using wiichuck adapter)
#define DEBUG_RCV_TEL 1
#define USE_NEW_WAY_INIT 1 // use "The New Way" of initialization <http://wiibrew.org/wiki/Wiimote#The_New_Way>
#define WII_IDENT_LEN ((byte)6)
#define WII_TELEGRAM_LEN ((byte)6)
#define WII_NUNCHUCK_TWI_ADR ((byte)0x52)
#include <Wire.h>
#include <string.h>
#include <utility\twi.h>
#undef int
#include <stdio.h>
uint8_t outbuf[WII_TELEGRAM_LEN]; // array to store arduino output
int cnt = 0;
int ledPin = 13;
void setup ()
Serial.begin (115200);
#ifdef POWER_VIA_PORT_C2_C3 // power supply of the Nunchuck via port C2 and C3
PORTC &=~ _BV(PORTC2);
PORTC |= _BV(PORTC3);
DDRC |= _BV(PORTC2) | _BV(PORTC3); // make outputs
delay(100); // wait for things to stabilize
#endif
Wire.begin(); // initialize i2c
// we need to switch the TWI speed, because the nunchuck uses Fast-TWI
// normally set in hardware\libraries\Wire\utility\twi.c twi_init()
// this is the way of doing it without modifying the original files
#define TWI_FREQ_NUNCHUCK 400000L
TWBR = ((CPU_FREQ / TWI_FREQ_NUNCHUCK) - 16) / 2;
nunchuck_init(0); // send the initialization handshake
// display the identification bytes, must be "00 00 A4 20 00 00" for the Nunchuck
byte i;
if(readControllerIdent(outbuf) == 0)
Serial.print("Ident=");
for (i = 0; i < WII_TELEGRAM_LEN; i++)
Serial.print(outbuf[i], HEX);
Serial.print(' ');
Serial.println();
Serial.println("Finished setup");
// params:
// timeout: abort when timeout (in ms) expires, 0 for unlimited timeout
// return: 0 == ok, 1 == timeout
byte nunchuck_init (unsigned short timeout)
byte rc = 1;
#ifndef USE_NEW_WAY_INIT
// look at <http://wiibrew.org/wiki/Wiimote#The_Old_Way> at "The Old Way"
Wire.beginTransmission (WII_NUNCHUCK_TWI_ADR); // transmit to device 0x52
Wire.send (0x40); // sends memory address
Wire.send (0x00); // sends sent a zero.
Wire.endTransmission (); // stop transmitting
#else
// disable encryption
// look at <http://wiibrew.org/wiki/Wiimote#The_New_Way> at "The New Way"
unsigned long time = millis();
do
Wire.send (0xF0); // sends memory address
Wire.send (0x55); // sends data.
if(Wire.endTransmission() == 0) // stop transmitting
Wire.send (0xFB); // sends memory address
if(Wire.endTransmission () == 0) // stop transmitting
rc = 0;
while (rc != 0 && (!timeout || ((millis() - time) < timeout)));
#endif
return rc;
// params:
// ident [out]: pointer to buffer where 6 bytes of identification is stored. Buffer must be at least 6 bytes long.
// A list of possible identifications can be found here: <http://wiibrew.org/wiki/Wiimote#The_New_Way>
// return: 0 == ok, 1 == error
byte readControllerIdent(byte* pIdent)
byte rc = 1;
// read identification
Wire.send (0xFA); // sends memory address of ident in controller
byte i;
Wire.requestFrom (WII_NUNCHUCK_TWI_ADR, WII_TELEGRAM_LEN); // request data from nunchuck
for (i = 0; (i < WII_TELEGRAM_LEN) && Wire.available (); i++)
pIdent[i] = Wire.receive(); // receive byte as an integer
if(i == WII_TELEGRAM_LEN)
rc = 0;
return rc;
void clearTwiInputBuffer(void)
// clear the receive buffer from any partial data
while( Wire.available ())
Wire.receive ();
void send_zero ()
// I don't know why, but it only works correct when doing this exactly 3 times
// otherwise only each 3rd call reads data from the controller (cnt will be 0 the other times)
for(byte i = 0; i < 3; i++)
Wire.send (0x00); // sends one byte
//delay(1);
void loop ()
delay (1000);
send_zero (); // send the request for next bytes
for (cnt = 0; (cnt < WII_TELEGRAM_LEN) && Wire.available (); cnt++)
outbuf[cnt] = nunchuk_decode_byte (Wire.receive ()); // receive byte as an integer
digitalWrite (ledPin, HIGH); // sets the LED on
// debugging
#ifdef DEBUG_RCV_TEL
Serial.print("avail=");
Serial.print(Wire.available(), DEC);
Serial.print(" cnt=");
Serial.println(cnt, DEC);
#endif
clearTwiInputBuffer();
// If we recieved the 6 bytes, then go print them
if (cnt >= WII_TELEGRAM_LEN)
print ();
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits. That is why I
// multiply them by 2 * 2
void print ()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2] * 2 * 2;
int accel_y_axis = outbuf[3] * 2 * 2;
int accel_z_axis = outbuf[4] * 2 * 2;
int z_button = 0;
int c_button = 0;
// byte outbuf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print (joy_x_axis, DEC);
Serial.print ("\t");
Serial.print (joy_y_axis, DEC);
Serial.print (accel_x_axis, DEC);
Serial.print (accel_y_axis, DEC);
Serial.print (accel_z_axis, DEC);
Serial.print (z_button, DEC);
Serial.print (c_button, DEC);
Serial.print ("\r\n");
// Decode data format that original Nunchuck uses with old init sequence. This never worked with
// other controllers (e.g. wireless Nunchuck from other vendors)
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
#endif
return x;
I can upload the code but it doesn’t seem to be reading the nunchuck
any help is appreciated
thanks
