Arduino and Orangutan B-328 Robot Controller not programming help pls.
Help plsss
Help plsss
Why are you trying to burn a bootloader on to your Baby Orangutan? That’s not going to work (without some hassle). Instead of using a bootloader, you should load your sketches on to the board using the Pololu USB AVR Programmer as an ISP programmer. The Arduino IDE has built-in support for doing this, by running the program “avrdude”. You should follow the instructions in this document to set this up: Programming Orangutans and the 3pi Robot from the Arduino Environment.
