I used the Micro Serial Servo Controller (MSSC) with Arduino
to build three dancing matryoshkas. The response
of the MSSC is satisfyingly quick to synchronize
the puppets to a tune (I took a Russian punk rock song)
To create the beat I used an external pushbutton connected
to an input of the Arduino. Ideally, this should create an
interrupt on the Arduino, but there is a problem
in connection with the library SoftwareSerial.h.
Once you use Arduino interrupts the timing does
not work properly any more and SoftwareSerial.h
cannot produce correct serial bytes.
I put a note about it on the arduino forum, maybe it will be solved
later.
arduino.cc/cgi-bin/yabb2/YaB … 8516/13#13
To overcome this problem I used an external Flip-Flop which
catches the signal from the button and must be reset from
Arduino once it took the signal.
Furthermore to turn the puppets to back and front I used
three lever switches.
I do not recommend using the regular Pins 0 and 1 used for serial
communication. You need them usually for debugging and controlling
your program. Better is to use the software serial. You can use the
following code framework
Pololu Template Program
It allows to set servos interactively.
by Hannes Hassler
based on examples by Tom Igoe, David Mellis and Heather Dewey-Hagborg
and on the contribution from Adam (nexisnet) in Thread
'https://forum.pololu.com/t/arduino-pololu-micro-serial-8-servo-controller/613/1&highlight=arduino'
discussing mostly between Adam, Phil and Zagrophyte
written: 20 Oct 2008
#include <SoftwareSerial.h>
#define reset 7
#define rxPin 6
#define txPin 5
// set up a new serial port
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
void setup() {
// define pin modes for tx, rx, led pins:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
pinMode(reset, OUTPUT);
resetPololu();
mySerial.begin(9600);
Serial.begin(9600);
void resetPololu() {
digitalWrite(reset, LOW);
delay(100);
digitalWrite(reset,HIGH);
void send2Pololu(int servo, int angle) {
//maxRightAngle 4850
//minLeftAngle 1100
unsigned char buff[6];
unsigned int temp;
unsigned char pos_hi,pos_low;
//Convert the angle data into two 7-bit bytes
temp=angle&0x1f80;
pos_hi=temp>>7;
pos_low=angle & 0x7f;
//Construct a Pololu Protocol command sentence
buff[0]=0x80; //start byte
buff[1]=0x01; //device id
buff[2]=0x04; //command number
buff[3]=servo; //servo number
buff[4]=pos_hi; //data1
buff[5]=pos_low; //data2
//Send the command to the servo controller
for(int i=0;i<6;i++){
mySerial.print(buff[i]);
void loop() {
static int v = 0;
static int servo = 0;
static int angle = 0;
static char ch;
static int left=1000;
static int right=3000;
if (Serial.available()) {
ch = Serial.read();
To set a specific servo interactively you
can use the folling scheme (type in the Serial port entry)
to select servo No 3, type : 3s
to set servo angle to 2000 : 2000a
to activate the servo respectively : d
set selected servo to its left value : l
set left value to 1100 : 1100L
set selected servo to its right value : r
set right value to 4500 : 4500R
reset Pololu : z
(reset pin 7 must be connected to reset pin of Pololu)
switch(ch) {
case '0'...'9':
v = v * 10 + ch - '0';
break;
case 's':
Serial.print("servo:");
Serial.println(v);
servo=v;
v = 0;
break;
case 'a':
Serial.print("angle:");
Serial.println(v);
angle=v;
v = 0;
break;
case 'd':
Serial.print("set servo No:");
Serial.print(servo);
Serial.print(" angle:");
Serial.println(angle);
send2Pololu(servo, angle);
break;
case 'l':
send2Pololu(servo,left);
break;
case 'L':
left=v;
Serial.print("left:");
Serial.println(v);
v=0;
break;
case 'r':
send2Pololu(servo,right);
break;
case 'R':
right=v;
Serial.print("right:");
Serial.println(v);
v=0;
break;
case 'z':
resetPololu();
break;
