Hello everyone;
I’m making an integration between TI launchpad Tiva C, and the AltImun v5 using S-functions in Matlab/Simulink. The code from the Arduino Libraries run fine with the INO file directly to the launchapad, but when I make the S-function and run in the launchpad, the code hangs in the line:
while (Wire.available() < 6)
The sensor have 3 blocks (magnetometer, temperature and gyro+acel), the temperature code works fine in matlab, but the magn and the gyro doesn’t work.
I follow the lines to the cpp and headers of Wire libraries, but I can’t find the problem.
Do you have some idea?
This is the code of the wrapped cpp file, the wire and the LIS3MDL libraries are the version downloaded from Pololu page:
#include <LIS3MDL.h>
#include <Wire.h>
#include <math.h>
// Defines ////////////////////////////////////////////////////////////////
// The Arduino two-wire interface uses a 7-bit number for the address,
// and sets the last bit correctly based on reads and writes
#define LIS3MDL_SA1_HIGH_ADDRESS 0b0011110
#define LIS3MDL_SA1_LOW_ADDRESS 0b0011100
#define TEST_REG_ERROR -1
#define LIS3MDL_WHO_ID 0x3D
// Constructors ////////////////////////////////////////////////////////////////
LIS3MDL::LIS3MDL(void)
_device = device_auto;
io_timeout = 0; // 0 = no timeout
did_timeout = false;
// Public Methods //////////////////////////////////////////////////////////////
// Did a timeout occur in read() since the last call to timeoutOccurred()?
bool LIS3MDL::timeoutOccurred()
bool tmp = did_timeout;
return tmp;
void LIS3MDL::setTimeout(uint16_t timeout)
io_timeout = timeout;
uint16_t LIS3MDL::getTimeout()
return io_timeout;
bool LIS3MDL::init(deviceType device, sa1State sa1)
// perform auto-detection unless device type and SA1 state were both specified
if (device == device_auto || sa1 == sa1_auto)
// check for LIS3MDL if device is unidentified or was specified to be this type
if (device == device_auto || device == device_LIS3MDL)
// check SA1 high address unless SA1 was specified to be low
if (sa1 != sa1_low && testReg(LIS3MDL_SA1_HIGH_ADDRESS, WHO_AM_I) == LIS3MDL_WHO_ID)
sa1 = sa1_high;
if (device == device_auto) { device = device_LIS3MDL; }
// check SA1 low address unless SA1 was specified to be high
else if (sa1 != sa1_high && testReg(LIS3MDL_SA1_LOW_ADDRESS, WHO_AM_I) == LIS3MDL_WHO_ID)
sa1 = sa1_low;
// make sure device and SA1 were successfully detected; otherwise, indicate failure
return false;
_device = device;
switch (device)
case device_LIS3MDL:
address = (sa1 == sa1_high) ? LIS3MDL_SA1_HIGH_ADDRESS : LIS3MDL_SA1_LOW_ADDRESS;
break;
return true;
Enables the LIS3MDL's magnetometer. Also:
- Selects ultra-high-performance mode for all axes
- Sets ODR (output data rate) to default power-on value of 10 Hz
- Sets magnetometer full scale (gain) to default power-on value of +/- 4 gauss
- Enables continuous conversion mode
Note that this function will also reset other settings controlled by
the registers it writes to.
void LIS3MDL::enableDefault(void)
if (_device == device_LIS3MDL)
// 0x70 = 0b01110000
// OM = 11 (ultra-high-performance mode for X and Y); DO = 100 (10 Hz ODR)
writeReg(CTRL_REG1, 0x70);
// 0x00 = 0b00000000
// FS = 00 (+/- 4 gauss full scale)
writeReg(CTRL_REG2, 0x00);
// MD = 00 (continuous-conversion mode)
writeReg(CTRL_REG3, 0x00);
// 0x0C = 0b00001100
// OMZ = 11 (ultra-high-performance mode for Z)
writeReg(CTRL_REG4, 0x0C);
// Writes a mag register
void LIS3MDL::writeReg(uint8_t reg, uint8_t value)
Wire.beginTransmission(address);
Wire.write(reg);
Wire.write(value);
last_status = Wire.endTransmission();
// Reads a mag register
uint8_t LIS3MDL::readReg(uint8_t reg)
uint8_t value;
Wire.write(reg);
Wire.requestFrom(address, (uint8_t)1);
value = Wire.read();
return value;
// Reads the 3 mag channels and stores them in vector m
void LIS3MDL::read()
// assert MSB to enable subaddress updating
Wire.write(OUT_X_L | 0x80);
Wire.requestFrom(address, (uint8_t)6);
uint16_t millis_start = millis();
if (io_timeout > 0 && ((uint16_t)millis() - millis_start) > io_timeout)
did_timeout = true;
return;
uint8_t xlm = Wire.read();
uint8_t xhm = Wire.read();
uint8_t ylm = Wire.read();
uint8_t yhm = Wire.read();
uint8_t zlm = Wire.read();
uint8_t zhm = Wire.read();
// combine high and low bytes
m.x = (int16_t)(xhm << 8 | xlm);
m.y = (int16_t)(yhm << 8 | ylm);
m.z = (int16_t)(zhm << 8 | zlm);
void LIS3MDL::vector_normalize(vector<float> *a)
float mag = sqrt(vector_dot(a, a));
a->x /= mag;
a->y /= mag;
a->z /= mag;
// Private Methods //////////////////////////////////////////////////////////////
int16_t LIS3MDL::testReg(uint8_t address, regAddr reg)
Wire.write((uint8_t)reg);
if (Wire.endTransmission() != 0)
return TEST_REG_ERROR;
if (Wire.available())
return Wire.read();
else
