I am having a little trouble using the ADC auto-triggered by the timer/counter on the Orangutan LV-168. Since I am everything else but experienced, it is probably some simple mistake I am making. Anyway, I would be very grateful for any help on this.
Here’s what I have done so far:
I have put a voltage I would like to measure on PC3 (ADC3) and have checked it already using the ADC without auto-triggering:
ADCSRA = 0x87; // bit 7 set: ADC enabled
// bit 6 clear: don't start conversion
// bit 5 clear: disable autotrigger
// bit 4: ADC interrupt flag
// bit 3 clear: disable ADC interrupt
// bits 0-2 set: ADC clock prescaler is 128
ADMUX = 0x03; // bit 7 and 6 clear: voltage ref is Vref pin
// bit 5 clear: right-adjust result (10-bit ADC)
// bit 4 not implemented
// bits 0-3: ADC channel (channel 3)
ADCSRA |= (1 << ADSC); // start conversion
while ( ADCSRA & ( 1 << ADSC )) // wait while converting
Displaying the result on ADC shows reasonable results, so the problem I have is definitely just auto-triggering the ADC at TCNT overflows.
So the following shows how I wanted to use auto-triggering:
// ******** Set up the timer/counter ******************************/
TCCR0A = 0x00; // normal operation mode
TCCR0B = 0x05; // 1024 prescaler => 20MHz / 1024 = ca. 20 kHz
/ *************Set up the ADC*********************************/
// bit 5 clear: disable autotrigger (set below)
ADCSRA |= 1 << ADATE; // Auto Trigger enable
ADCSRB = 0x04; // triggered by TCNT0 Overflow
Checking the ADC values on the LCD it seems like the MCU is doing either one single conversion or no conversion at all. I am not completely sure, because I have tried this on both the LV168 and on an ATtiny13. The LCD shows on constant value, so I think it does one conversion. The ATtiny13 application always gives me 0 as the result, but maybe there is a mistake on the PCB I am using with the tiny13…
Thanks in advance for your help!!
-Robert
