Hi, ive only had a brief look over the documentation and on the forum so may have missed something but is there any way to access a RS-232 output or the UART output i know the main communication is though a usb that appears as a serial port to the computer but for some hardware i wish to interface it needs UART TTL logic levels
i have a chip that can convert from RS-232 to UART logic (MAX232 IC) if needed
-Sean
edit: thanks paul now i look at the schematic i can clearly see we have access to the rxd and txd via PORTD. i kept trying to find a solution using the serial communications generally used with the X2 when such an obvious and easy to implement answer is right there. silly me
