Hi everyone !
I’m working on the flightsense sensor thanks to the expansion board X-Nucleo-6180XA1 and a satellite on a STM32F401RE. And I have some questions :
I would like to know the accuracy of the sensor ?
Also, I want to use it to determine a distance between the sensor and a target.
I have implemented the example code and adapted it to my situation. I would like to measure the distance with at least 0.5mm of precision. But the sensor send only the result in millimeter by the I²C bus .
Is it possible to have a more accurate measure ?
Finally, I work on STM32F103 thanks to the SPL library and not with the HAL library. I tried to implement a code but unsuccessful …
Do you have an example with this library ?
Thanks in advance,
Best regards,
Julien
