Hey Everyone,
I am a student from Pakistan currently working on my final year project. I want to get 90 degree beam angle by using VL53L0X. how can i do this with great accuracy?
How can I configure this on Arduino?
As mentioned in the sensor datasheet, the Field Of View (FOV) for the VL53L0X is 25 degrees. There is no way to expand the FOV. Instead, you might consider setting up multiple sensors if you want to cover a wider area. It might be useful to look at this thread if you decide to do that.
Alternatively, you might consider seeing if our 3-Channel Wide FOV Time-of-Flight Distance Sensor Using OPT3101 might be a better fit for your application. It has a nearly 180 degree FOV, and the maximum range is about one meter.
- Patrick
