Currently I am using MinIMU-9 (pololu.com/catalog/product/1264) to do the “shoe mounted inertial navigation system for pedestrian” project. I need to read the acc, gyro and magnetic values from the MinIMU-9 at a very high frequency. I set the gyro, acc and mag with following setting:
a. gyro: normal power mode, data rate 800Hz, 110 cut-off, dynamic range 2000 dps
b. acc: normal power mode, data rate 1000Hz, 780 cut-off, the dynamic range ± 8g
c. mag: data rate 220Hz, range 1.3 gauss
I use the Arduino board to read the senor through I2C interface, and use the provided library code downloaded from the Pololu website. But I got two issues:
for each loop, I read the three sensors, and print out the values to the serial port without any delay. But I found that each loop took around 5ms, in which the library “read()” function took around 3+ ms. This causes the highest frequency of the output is less than 200Hz, but I need higher frequency, e.g. 300Hz or 400Hz. How can I achieve that?
The second issue is about time synchronization. In each loop, besides the sensor data, I also record the current timestamp using “micros()” and print it to the serial port. However, since the “gyro.read()” and “compass.read()” functions take more than 3ms, I am not sure whether the timestamp I recorded is close enough to the true reading time. Since my project is very sensitive to the timestamp, I dont know whether there is a better way to do the time syncrhonization.
The code is listed below. Please help to ask my questions. I really appreciate it! Thanks!
[code]
#include <Wire.h>
#include <L3G.h>
#include <LSM303.h>
LSM303 compass;
L3G gyro;
unsigned long counter;
unsigned long time;
void setup() {
Serial.begin(115200);
Wire.begin();
if (!gyro.init())
Serial.println(“Failed to autodetect gyro type!”);
while (1);
gyro.enableDefault();
compass.init();
compass.enableDefault();
///////////////////////////////////////////Gyro setting///////////////////////////////////////////
//set gyro range to 2000dps
gyro.writeReg(L3G_CTRL_REG4, 0x20);
//set gyro in normal power mode, with 100Hz rate, 12.5 cut-off
//gyro.writeReg(L3G_CTRL_REG1, 0x0F);
//set gyro in normal power mode, with 400Hz rate, 50 cut-off
//gyro.writeReg(L3G_CTRL_REG1, 0xAF);
//set gyro in normal power mode, with 800Hz rate, 110 cut-off
gyro.writeReg(L3G_CTRL_REG1, 0xFF);
///////////////////////////////////////////ACC setting///////////////////////////////////////////
//set acc sensor range to ±8g
compass.writeAccReg(LSM303_CTRL_REG4_A, 0x30);
//set acc in normal power mode, with 100Hz rate, 74 cut-off
//compass.writeAccReg(LSM303_CTRL_REG1_A, 0x2F);
//set acc in normal power mode, with 400Hz rate, 292 cut-off
//compass.writeAccReg(LSM303_CTRL_REG1_A, 0x37);
//set acc in normal power mode, with 1000Hz rate, 780 cut-off
compass.writeAccReg(LSM303_CTRL_REG1_A, 0x3F);
///////////////////////////////////////////Mag setting///////////////////////////////////////////
//set mag rate 220Hz
compass.writeMagReg(LSM303_CRA_REG_M, 0x1C);
//set mag range 1.3 gauss, x/y 1100 LSB/Gauss, Z 980 LSB/Gauss
compass.writeMagReg(LSM303_CRB_REG_M, 0x20);
//set mag in continuous-conversion mode
compass.writeMagReg(LSM303_MR_REG_M, 0x00);
Serial.print("Gyro mode (L3G_CTRL_REG1): ");
Serial.println(gyro.readReg(L3G_CTRL_REG1));
Serial.print("Gyro Scaling status (L3G_CTRL_REG4): ");
Serial.println(gyro.readReg(L3G_CTRL_REG4));
Serial.print("Acc mode (LSM303_CTRL_REG1_A): ");
Serial.println(compass.readAccReg(LSM303_CTRL_REG1_A));
Serial.print("Acc Scaling status (LSM303_CTRL_REG4_A): ");
Serial.println(compass.readAccReg(LSM303_CTRL_REG4_A));
Serial.print("Mag mode (LSM303_MR_REG_M): ");
Serial.println(compass.readMagReg(LSM303_MR_REG_M));
Serial.print("Mag Scaling status(A) (LSM303_CRA_REG_M): ");
Serial.println(compass.readMagReg(LSM303_CRA_REG_M));
Serial.print("Mag Scaling status(B) (LSM303_CRB_REG_M): ");
Serial.println(compass.readMagReg(LSM303_CRB_REG_M));
counter = 0;
time = 0;
void loop() {
//if (micros() - time > 20000 )
time = micros();
gyro.read();
compass.read();
counter = counter+1;
Serial.print((int)gyro.g.x);
Serial.print(" ");
Serial.print((int)gyro.g.y);
Serial.print(" ");
Serial.print((int)gyro.g.z);
Serial.print(" ");
Serial.print((int)compass.a.x);
Serial.print(" ");
Serial.print((int)compass.a.y);
Serial.print(" ");
Serial.print((int)compass.a.z);
Serial.print(" ");
Serial.print((int)compass.m.x);
Serial.print(" ");
Serial.print((int)compass.m.y );
Serial.print(" ");
Serial.print((int)compass.m.z);
Serial.print(" ");
Serial.print(time);
Serial.print(" ");
Serial.println(counter);
}[/code]
