Are you running two stepper motors with the setup you described in your last post? If so, please note that when using two stepper motors in parallel, you should set the current limit to be twice the current per phase rating of those stepper motors (e.g. if each stepper motor is rated for 100mA per phase, you should set the current limit to 200mA when using them in parallel).
-Brandon
