Aloha Jon –
Thanks for the response. Kinda getting matters in hand. What stumps me are the delay()'s I had to add into the code to get things underway. Commenting out the serial data, and adding the minimum of delay()'s obtained through testing, I get reasonable response over RF. That done, I had to write in 4 new variables, as just mapping x&y to new values for PWM did not seem to work. I operate the joystick in a “+” fashion, as written in the code, although I seem to get differential turning with stick approaching “x” positions (under investigation). Code below.
void loop() {
if ( radio.available() )
bool done = false;
while (!done)
done = radio.read( joystick, sizeof(joystick) );
//Serial.print("X = ");
//Serial.print(joystick[0]); // x value
//Serial.print(" Y = ");
//Serial.println(joystick[1]); // y value
x = joystick[0];
y = joystick[1];
//**********BEGIN HERE RF CONTROL OF MOTORS********
if (y > 532)
fory = map(y, 512, 1023, 0, 200);
digitalWrite (AIN1,HIGH);
digitalWrite (AIN2,LOW);
digitalWrite (BIN1,HIGH);
digitalWrite (BIN2,LOW);
analogWrite(PWMA,fory);
analogWrite(PWMB,fory);
delay(40);
if (y < 492)
revy = map(y, 0, 512, 200, 0);
digitalWrite (AIN1,LOW);
digitalWrite (AIN2,HIGH);
digitalWrite (BIN1,LOW);
digitalWrite (BIN2,HIGH);
analogWrite(PWMA,revy);
analogWrite(PWMB,revy);
delay(40);
if (492 < y < 532)
if (x > 532) // turn right, zero point turn
rtx = map(x, 512, 1023, 0, 200);
analogWrite(PWMA,rtx);
analogWrite(PWMB,rtx);
delay(40);
if (x < 492) // turn left, zero point turn
lex = map(x, 0, 512, 200, 0);
analogWrite(PWMA,lex);
analogWrite(PWMB,lex);
delay(40);
if ( 492 < y < 532 && 492 < x < 532) // joystick centered
Stop();
else //****IF NO RADIO, GO TO OBSTACLE CHECKING
robotControl();
//Serial.println("No radio available");
delay(50);
} //********END LOOP*********
I built up a quickie transmitter in this process with an AMini, moving from the BB’d328P-PU. Maybe that was the trick. Anyway, love these A’s, as those blue-colored Micro’s are always giving me headaches when trying to just drop a sketch onto it. Am posting full code below, in case anyone can suggest improvements. I am particularly interested in improving the chooseLR() function such that gives less predictable actions by the bot. Meaning, well, noobing, I lack the words to describe.
A hui hou
Mark
[code]//AStar_md08a_Tamiya_nRF24
//24 Aug 2014
//********RADIO STUFF
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <NewPing.h>
#define CE_PIN 4
#define CSN_PIN 9
//PING STUFF***
#define TRIGPIN A0
#define ECHOPIN A1
#define MAXDIST 500
#define COLLDIST 20
#define CLOSINGDIST 40
//#define ALERTDIST COLLDIST*3
NewPing sonar(TRIGPIN, ECHOPIN, MAXDIST); // Ping sensor pins for library
//MOTOR DRIVER STUFF
#define PWMA 10
#define AIN1 7
#define AIN2 8
#define PWMB 11
#define BIN1 6
#define BIN2 5
#define STBY 12 // HIGH to enable, LOW to disable
#define MAXSPEED 120
int speedSet = 0;
//MORE RADIO STUFF*****
const uint64_t pipe = 0xE8E8F0F0E1LL;
RF24 radio(CE_PIN, CSN_PIN);
int joystick[2];
int x = 0;
int y = 0;
//int speedX = 0;
//int speedY = 0;
//MOTOR SPEED VARIABLES OVER RADIO**
int fory = 0;
int revy = 0;
int rtx = 0;
int lex = 0;
//**PING VARS & PING FUNCTION
int curDist = 0;
int val[3];
//const int numReadings = 3;
int readPing() {
delay(50);
unsigned int uS = sonar.ping();
int cm = uS/US_ROUNDTRIP_CM;
return cm;
//***SETUP
void setup() {
Serial.begin(9600);
//md08a motor driver
pinMode(PWMA,OUTPUT);
pinMode(AIN1,OUTPUT);
pinMode(AIN2,OUTPUT);
pinMode(STBY,OUTPUT);
pinMode(BIN1,OUTPUT);
pinMode(BIN2,OUTPUT);
pinMode(PWMB,OUTPUT);
val[0] = 0;
val[1] = 0;
val[2] = 0;
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
delay(2000);
digitalWrite(STBY,HIGH);
Forward();
//LOOP****
void loop() {
bool done = false;
while (!done)
//Serial.print("X = “);
//Serial.print(” Y = ");
x = joystick[0];
y = joystick[1];
//**BEGIN HERE RF CONTROL OF MOTORS
if (y > 532)
delay(40);
if (y < 492)
delay(40);
if (492 < y < 532)
delay(40);
delay(40);
Stop();
else //***IF NO RADIO, GO TO OBSTACLE CHECKING
robotControl();
//Serial.println(“No radio available”);
delay(50);
} //END LOOP
//OBSTACLE CHECKING
void robotControl(){
curDist = readPing(); // read distance
if (curDist < CLOSINGDIST)
if (curDist < COLLDIST)
changePath();
else
aheadSlow();
else Forward();
//PING CONTROL
void changePath(){
Stop();
turnLeft();
delay(500);
Stop();
delay(100);
val[0] = curDist; //take left reading
delay(100);
turnRight();
delay(500);
Stop();
delay(100);
val[1] = curDist; //take center reading
delay(100);
turnRight();
delay(500);
Stop();
delay(100);
val[2] = curDist; //take right reading
delay(100);
turnLeft();
delay(500);
chooseLR();
void chooseLR(){ //changed this funxn from V3
if(val[0] > COLLDIST) // left clear
if(val[2] > COLLDIST) //right clear
if(val[0] > val[2])// left is more clear
turnLeft();
delay(500);
Forward();
else
turnRight();
delay(500);
Forward();
else
turnLeft();
delay(500);
Forward();
else
turnRight();
delay(500);
Forward();
else
Reverse();
delay(600);
if (random(2) == 0)
turnLeft();
delay(500);
else turnRight();
delay(500);
//MOTOR CONTROL**
void Forward ()
Serial.println(“Forward”);
//for (speedSet = 0; speedSet < MAXSPEED; speedSet +=1)
for (speedSet = 0; speedSet < MAXSPEED; ++speedSet)
analogWrite(PWMA,speedSet);
analogWrite(PWMB,speedSet);
//delay(5);
delay(5);
void aheadSlow ()
Serial.println(“Ahead slow”);
analogWrite(PWMA,MAXSPEED0.5);
analogWrite(PWMB,MAXSPEED0.5);
delay(10);
void Reverse ()
Serial.println(“Reverse”);
analogWrite(PWMA,speedSet0.5);
analogWrite(PWMB,speedSet0.5);
delay(5);
void turnLeft ()
Serial.println(“Turning left”);
delay(5);
void turnRight ()
Serial.println(“Turning right”);
delay(5);
void Stop ()
Serial.println(“Stopped”);
analogWrite(PWMA,255);
analogWrite(PWMB,255);
void turnAround()
Reverse();
delay(500);
turnLeft();
delay(600);
[/code]
