I have a A-Star 8MHz 3.3V.
I am using the Arduino IDE 1.8.7.
I can upload a Sketch to my A-Star with the FTDI without any problem.
When I use my Pololu “USB AVR Programmer v2.1” I cannot upload the Sketch.
The A-Star is powered and the USB AVR Programmer connected.
The Green LED on the Programmer is ON / The Yellow LED blinks.
The Configuration Utility:
The complete (verbose) error:
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:\TechLibrary\Arduino\arduino-1.8.7-windows\arduino-1.8.7\hardware\tools\avr/etc/avrdude.conf"
Additional configuration file is "C:\Users\Robert\AppData\Local\Arduino15\packages\pololu-a-star\hardware\avr\4.0.2/extra_avrdude.conf"
avrdude: warning at C:\Users\Robert\AppData\Local\Arduino15\packages\pololu-a-star\hardware\avr\4.0.2/extra_avrdude.conf:1: part m328pb overwrites previous definition D:\TechLibrary\Arduino\arduino-1.8.7-windows\arduino-1.8.7\hardware\tools\avr/etc/avrdude.conf:8802.
Using Port : COM17
Using Programmer : stk500
Setting bit clk period : 0.5
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500
Programmer Model: STK500
Hardware Version: 15
Firmware Version Master : 2.10
Topcard : Unknown
Vtarget : 3.3 V
SCK period : 0.5 us
Varef : 0.0 V
Oscillator : Off
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
An error occurred while uploading the sketch
