A-star 32u4 and a bit of translation
Hello!
Basiclaly, I am trying to use a 32u4 for an Adalight project (learn.adafruit.com/adalight-diy … v-lighting)
Now, I have figured out that the 32u4 has the SPI-interface in the ISP-header. Great. But i am trying to figure out how to modify the sketch to run with 32u4 instead of an Uno (or similar). Basically, I have tried quite a few versions of pin definitions without any joy. Could someone offer up advice to wireing/config?
If i do use an Arduino Uno all is well. But i like the 32u4 as it is small enough to just mount behind the TV.
// LED pin for Adafruit 32u4 Breakout Board: //#define LED_DDR DDRE //#define LED_PORT PORTE //#define LED_PIN _BV(PORTE6) // LED pin for Teensy: //#define LED_DDR DDRD //#define LED_PORT PORTD //#define LED_PIN _BV(PORTD6) // LED pin for Arduino: #define LED_DDR DDRB #define LED_PORT PORTB #define LED_PIN _BV(PORTB5)
The A-Star 32U4 Micro uses Atmel’s ATmega32U4 microcontroller. Uncommenting the #define lines for the LED pins under the “32u4 Breakout Board” (and commenting the lines under “Arduino”) and connecting to the MOSI and SCLK pins on the A* should work:
// LED pin for Adafruit 32u4 Breakout Board: #define LED_DDR DDRE #define LED_PORT PORTE #define LED_PIN _BV(PORTE6) // LED pin for Teensy: //#define LED_DDR DDRD //#define LED_PORT PORTD //#define LED_PIN _BV(PORTD6) // LED pin for Arduino: //#define LED_DDR DDRB //#define LED_PORT PORTB //#define LED_PIN _BV(PORTB5)
- Jeremy
[quote=“JeremyT”]Hello.
The A-Star 32U4 Micro uses Atmel’s ATmega32U4 microcontroller. Uncommenting the #define lines for the LED pins under the “32u4 Breakout Board” (and commenting the lines under “Arduino”) and connecting to the MOSI and SCLK pins on the A* should work:[/quote]
Hello!
First, I would like to apologize for making my post a bit vague and thereby wasting your time :slight_smile:
That (changing the defs) to those of the 32u4 was one of the first things i tried. But, i got no response from the LED strand when I did do. That is when I started trying “Other stuff”.
But, If i read you correctly, changing the defs and hooking up to the ISP-header should be all I need to do?
I hooked up an oscilloscop (well, a cheap DSO clone…) and I do not see a pulse train on the ISP pins the same way as I do when I try with the (working) Arduino UNO.
So, any advice on what I should check next?
Thanks!
[/quote]
Found the issue. And now I feel slightly silly. I have now noticed that uploading of skethes was a bit hit-and-miss to the Pololu when I hade the USB connected to a USB3-port on my computer. Since moving it to USB2 all has been well.
So, I am leaning towards that I was simply running with the “wrong sketch” when i thought I hade the correct defines. And the “correct sketch” when i tried with other (incorrect) defines.
Oh, also, using USB3 from another computer seem to be fine also.
Again, my apologies.
I am glad you got it working. Thanks for letting us know.
By the way, I do not generally expect there to be any issues when programming the A* through a USB 3.0 port.
- Jeremy
[quote=“JeremyT”]I am glad you got it working. Thanks for letting us know.
  • Jeremy[/quote]
Nah, I will chalk this upp to buggy/strange USB3 drivers for that system. I have now tried it on a third and fourth computer. No issues at all with USB3 there either.
