Hello I created a card with a drv8825 but I can’t get it to work. The code I use works because I already tested it on another card. So it must be my card, could you tell me if my wiring is good? I followed the recommendations given by the datasheet of the documents.
From a quick look I do not see any obvious issues with your schematic. We cannot offer much help troubleshooting a board you routed, but if you are confident your other setup matches your board, you might try looking for routing issues or loose connections.
