I have a 3PI and wanted to be able to load the original demo code for arduino. I wasn’t able to find an official version of the code, but I figured it would be a good excersize in learning to code to copy and paste it into the arduino environment and then make it work again. I changed the function calls to the Library::function format since it makes it orange in the code for me.
I have the code here if anyone else wants it:
* 3pi-demo-program - demo code for the Pololu 3pi Robot arduino
* https://www.pololu.com/docs/0J20
* https://forum.pololu.com
// The following libraries will be needed by this demo
#include <Pololu3pi.h>
#include <PololuQTRSensors.h>
#include <OrangutanMotors.h>
#include <OrangutanAnalog.h>
#include <OrangutanLEDs.h>
#include <OrangutanLCD.h>
#include <OrangutanPushbuttons.h>
#include <OrangutanBuzzer.h>
Pololu3pi robot;
// This include file allows data to be stored in program space. The
// ATmega168 has 16k of program space compared to 1k of RAM, so large
// pieces of static data should be stored in program space.
#include <avr/pgmspace.h>
// Introductory messages. The "PROGMEM" identifier causes the data to
// go into program space.
const char welcome_line1[] PROGMEM = " Pololu";
const char welcome_line2[] PROGMEM = "3\xf7 Robot"; // \xf7 is a greek
// pi character
const char demo_name_line1[] PROGMEM = "Demo";
const char demo_name_line2[] PROGMEM = "Arduino";
const char instructions_line1[] PROGMEM = "Use B to";
const char instructions_line2[] PROGMEM = "select.";
const char instructions_line3[] PROGMEM = "Press B";
const char instructions_line4[] PROGMEM = "-try it!";
const char thank_you_line1[] PROGMEM = " Thank ";
const char thank_you_line2[] PROGMEM = " you!";
const char main_menu_intro_line1[] PROGMEM = " Main";
const char main_menu_intro_line2[] PROGMEM = " Menu";
const char menu_bat_test[] PROGMEM = "Battery";
const char menu_led_test[] PROGMEM = "LEDs";
const char menu_lcd_test[] PROGMEM = "LCD";
const char menu_ir_test[] PROGMEM = "Sensors";
const char menu_motor_test[] PROGMEM = "Motors";
const char menu_music_test[] PROGMEM = "Music";
const char menu_pot_test[] PROGMEM = "Trimpot";
const char menu_time_test[] PROGMEM = "Timer";
const char menu_line2[] PROGMEM = "\x7f" "A \xa5" "B C\x7e";
const char back_line2[] PROGMEM = "\6B";
const char fugue[] PROGMEM =
"! T120O5L16agafaea dac+adaea fa<aa<bac#a dac#adaea f"
"O6dcd<b-d<ad<g d<f+d<gd<ad<b- d<dd<ed<f+d<g d<f+d<gd<ad"
"L8MS<b-d<b-d MLe-<ge-<g MSc<ac<a MLd<fd<f O5MSb-gb-g"
"ML>c#e>c#e MS afaf ML gc#gc# MS fdfd ML e<b-e<b-"
"O6L16ragafaea dac#adaea fa<aa<bac#a dac#adaea faeadaca"
"<b-acadg<b-g egdgcg<b-g <ag<b-gcf<af dfcf<b-f<af"
"<gf<af<b-e<ge c#e<b-e<ae<ge <fe<ge<ad<fd"
"O5e>ee>ef>df>d b->c#b->c#a>df>d e>ee>ef>df>d"
"e>d>c#>db>d>c#b >c#agaegfe fO6dc#dfdc#<b c#4";
const char fugue_title[] PROGMEM = " \7 Fugue in D Minor - by J.S. Bach \7 ";
void bat_test();
void led_test();
void lcd_test();
void ir_test();
void motor_test();
void music_test();
void time_test();
void pot_test();
typedef void (*function)();
const function main_menu_functions[] = { bat_test, led_test, pot_test, ir_test, motor_test, music_test, time_test };
const char *main_menu_options[] = { menu_bat_test, menu_led_test, menu_pot_test, menu_ir_test, menu_motor_test, menu_music_test, menu_time_test };
const char main_menu_length = sizeof(main_menu_options)/sizeof(main_menu_options[0]);
// A couple of simple tunes, stored in program space.
const char welcome[] PROGMEM = ">g32>>c32";
const char thank_you_music[] PROGMEM = ">>c32>g32";
const char beep_button_a[] PROGMEM = "!c32";
const char beep_button_b[] PROGMEM = "!e32";
const char beep_button_c[] PROGMEM = "!g32";
const char timer_tick[] PROGMEM = "!v8>>c32";
// Data for generating the characters used in load_custom_characters
// and display_readings. By reading levels[] starting at various
// offsets, we can generate all of the 7 extra characters needed for a
// bargraph. This is also stored in program space.
const char levels[] PROGMEM = {
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
// This character is a musical note.
const char note[] PROGMEM = {
0b00100,
0b00110,
0b00101,
0b00101,
0b00100,
0b11100,
0b11100,
0b00000,
// This character is a back arrow.
const char back_arrow[] PROGMEM = {
0b00000,
0b00010,
0b00001,
0b00101,
0b01001,
0b11110,
0b01000,
0b00100,
// This function loads custom characters into the LCD. Up to 8
// characters can be loaded; we use them for 6 levels of a bar graph
// plus a back arrow and a musical note character.
void load_custom_characters()
OrangutanLCD::loadCustomCharacter(levels+0,0); // no offset, e.g. one bar
OrangutanLCD::loadCustomCharacter(levels+1,1); // two bars
OrangutanLCD::loadCustomCharacter(levels+2,2); // etc...
OrangutanLCD::loadCustomCharacter(levels+4,3); // skip level 3
OrangutanLCD::loadCustomCharacter(levels+5,4);
OrangutanLCD::loadCustomCharacter(levels+6,5);
OrangutanLCD::loadCustomCharacter(back_arrow,6);
OrangutanLCD::loadCustomCharacter(note,7);
OrangutanLCD::clear(); // the LCD must be cleared for the characters to take effect
// 10 levels of bar graph characters
const char bar_graph_characters[10] = {' ',0,0,1,2,3,3,4,5,255};
// Displays the battery voltage.
void bat_test()
int bat = OrangutanAnalog::readBatteryMillivolts();
OrangutanLCD::print(bat);
OrangutanLCD::print("mV");
delay(100);
char wait_for_250_ms_or_button_b()
int i;
for(i=0;i<25;i++)
delay(10);
if(OrangutanPushbuttons::isPressed(BUTTON_B))
return 1;
return 0;
// Blinks the LEDs
void led_test()
OrangutanBuzzer::play("c32");
OrangutanLCD::print("Red ");
OrangutanLEDs::red(HIGH);
if(wait_for_250_ms_or_button_b())
return;
OrangutanLEDs::red(LOW);
return;
OrangutanBuzzer::play(">c32");
OrangutanLCD::gotoXY(0,0);
OrangutanLCD::print("Green");
OrangutanLEDs::green(HIGH);
return;
OrangutanLEDs::green(LOW);
return;
void ir_test()
unsigned int sensors[5]; // an array to hold sensor values
if(OrangutanPushbuttons::isPressed(BUTTON_C))
read_line_sensors(sensors, IR_EMITTERS_OFF);
else
read_line_sensors(sensors,IR_EMITTERS_ON);
unsigned char i;
for(i=0;i<5;i++) {
// Initialize the array of characters that we will use for the
// graph. Using the space, an extra copy of the one-bar
// character, and character 255 (a full black box), we get 10
// characters in the array.
// The variable c will have values from 0 to 9, since
// values are in the range of 0 to 2000, and 2000/201 is 9
// with integer math.
char c = bar_graph_characters[sensors[i]/201];
// Display the bar graph characters.
OrangutanLCD::print(c);
// Display an indicator of whether IR is on or off
print("IR-");
else
print(" C");
delay(100);
int m1_speed = 0;
int m2_speed = 0;
void motor_test()
static char m1_back = 0, m2_back = 0;
char m1_char, m2_char;
if(OrangutanPushbuttons::isPressed(BUTTON_A))
if(m1_speed == 0)
delay(200);
// If the button is pressed quickly when the motor is off,
// reverse direction.
if(!OrangutanPushbuttons::isPressed(BUTTON_A))
m1_back = !m1_back;
m1_speed += 10;
else
m1_speed -= 20;
if(m2_speed == 0)
delay(200);
if(!OrangutanPushbuttons::isPressed(BUTTON_C))
m2_back = !m2_back;
m2_speed += 10;
else
m2_speed -= 20;
if(m1_speed < 0)
m1_speed = 0;
if(m1_speed > 255)
m1_speed = 255;
if(m2_speed < 0)
m2_speed = 0;
if(m2_speed > 255)
m2_speed = 255;
// 255/26 = 9, so this gives values in the range of 0 to 9
m1_char = bar_graph_characters[m1_speed / 26];
m2_char = bar_graph_characters[m2_speed / 26];
OrangutanLCD::print(m1_char);
OrangutanLCD::print(m1_back ? 'a' : 'A');
OrangutanLCD::gotoXY(5, 0);
OrangutanLCD::print(m2_char);
OrangutanLCD::print(m2_back ? 'c' : 'C');
OrangutanMotors::setSpeeds(m1_speed * (m1_back ? -1 : 1), m2_speed * (m2_back ? -1 : 1));
delay(50);
void music_test()
static char fugue_title_pos = 0;
static long last_shift = 0;
char c,i;
if(millis() - last_shift > 250)
for(i=0;i<8;i++)
c = pgm_read_byte(fugue_title + fugue_title_pos + i);
last_shift = millis();
fugue_title_pos ++;
if(fugue_title_pos + 8 >= sizeof(fugue_title))
if(!OrangutanBuzzer::isPlaying())
OrangutanBuzzer::playFromProgramSpace(fugue);
delay(100);
void pot_test()
long start = millis();
char elapsed_ms;
int value;
OrangutanAnalog::setMode(MODE_10_BIT);
OrangutanLCD::print(OrangutanAnalog::readTrimpot());
OrangutanLCD::print(" "); // to clear the display
while((elapsed_ms = millis() - start) < 100)
value = OrangutanAnalog::readTrimpot();
OrangutanBuzzer::playFrequency(value, 200, 15);
if(value < elapsed_ms*10)
else
void time_test()
static long elapsed_time = 0;
static long last_read = 0;
static long is_ticking = 0;
static char a_is_pressed = 0;
static char c_is_pressed = 0;
static char last_seconds = 0;
long current_time = millis();
if(is_ticking)
elapsed_time += current_time - last_read;
last_read = current_time;
if(OrangutanPushbuttons::isPressed(BUTTON_A) && !a_is_pressed)
// reset
a_is_pressed = 1;
is_ticking = 0;
elapsed_time = 0;
if(!OrangutanBuzzer::isPlaying()) // only play once
OrangutanBuzzer::playFromProgramSpace(beep_button_a);
// find the end of the button press without stopping
a_is_pressed = 0;
if(OrangutanPushbuttons::isPressed(BUTTON_C) && !c_is_pressed)
// start/stop
c_is_pressed = 1;
is_ticking = !is_ticking;
OrangutanBuzzer::playFromProgramSpace(beep_button_c);
c_is_pressed = 0;
OrangutanLCD::print((elapsed_time/1000/60/10)%10); // tens of minutes
OrangutanLCD::print((elapsed_time/1000/60)%10); // minutes
OrangutanLCD::print(':');
OrangutanLCD::print((elapsed_time/1000)%60/10); // tens of seconds
char seconds = ((elapsed_time/1000)%60)%10;
OrangutanLCD::print(((elapsed_time/1000)%60)%10); // seconds
OrangutanLCD::print('.');
OrangutanLCD::print((elapsed_time/100)%10); // tenths of seconds
OrangutanLCD::print((elapsed_time/10)%10); // hundredths of seconds
// beep every second
if(seconds != last_seconds && elapsed_time != 0 && !is_playing())
OrangutanBuzzer::playFromProgramSpace(timer_tick);
last_seconds = seconds;
void print_two_lines_delay_1s(const char *line1, const char *line2)
// Play welcome music and display a message
OrangutanLCD::printFromProgramSpace(line1);
OrangutanLCD::gotoXY(0,1);
OrangutanLCD::printFromProgramSpace(line2);
delay(1000);
// waits for a button, plays the appropriate beep, and returns the
// button or buttons that were pressed
char wait_for_button_and_beep()
char button = wait_for_button_press(ANY_BUTTON);
if(button & BUTTON_A)
else if(button & BUTTON_B)
OrangutanBuzzer::playFromProgramSpace(beep_button_b);
else
wait_for_button_release(button);
return button;
// Initializes the 3pi, displays a welcome message, calibrates, and
// plays the initial music.
void setup()
// This must be called at the beginning of 3pi code, to set up the
// sensors. We use a value of 2000 for the timeout, which
// corresponds to 2000*0.4 us = 0.8 ms on our 20 MHz processor.
robot.init(2000);
load_custom_characters(); // load the custom characters
OrangutanBuzzer::playFromProgramSpace(welcome);
print_two_lines_delay_1s(welcome_line1,welcome_line2);
print_two_lines_delay_1s(demo_name_line1,demo_name_line2);
print_two_lines_delay_1s(instructions_line1,instructions_line2);
OrangutanLCD::printFromProgramSpace(instructions_line3);
OrangutanLCD::printFromProgramSpace(instructions_line4);
while(!(wait_for_button_and_beep() & BUTTON_B));
OrangutanBuzzer::playFromProgramSpace(thank_you_music);
print_two_lines_delay_1s(thank_you_line1,thank_you_line2);
void menu_select()
static int menu_index = 0;
print_two_lines_delay_1s(main_menu_intro_line1,main_menu_intro_line2);
while(1)
OrangutanLCD::printFromProgramSpace(menu_line2);
OrangutanLCD::printFromProgramSpace(main_menu_options[menu_index]);
OrangutanLCD::showCursor(CURSOR_BLINKING);
// the cursor will be blinking at the end of the option name
// wait for all buttons to be released, then a press
while(OrangutanPushbuttons::isPressed(ANY_BUTTON));
menu_index --;
OrangutanLCD::hideCursor();
while(!OrangutanPushbuttons::isPressed(BUTTON_B))
OrangutanLCD::printFromProgramSpace(back_line2);
main_menu_functions[menu_index]();
OrangutanMotors::setSpeeds(0,0);
OrangutanBuzzer::stopPlaying();
m1_speed = 0;
m2_speed = 0;
OrangutanLEDs::red(0);
OrangutanLEDs::green(0);
return;
else if(button & BUTTON_C)
menu_index ++;
if(menu_index < 0)
menu_index = main_menu_length-1;
if(menu_index >= main_menu_length)
menu_index = 0;
// This is the main function, where the code starts. All C programs
// must have a main() function defined somewhere.
void loop()
menu_select();
// Local Variables: **
// mode: C **
// c-basic-offset: 4 **
// tab-width: 4 **
// indent-tabs-mode: t **
// end: **
