I Think This is the correct one
OrangutanDigital.h - Library for using the digital I/O lines on the
Orangutan LV, SV, SVP, X2, Baby Orangutan B, or 3pi robot. The code
is all inline, which lets it compile to very small, fast, efficient
assembly code if you use constants as your inputs. For example,
the line:
setOutput(3, HIGH);
compiles to the assembly:
sbi 0x0b, 3 ;i.e. PORTD |= 1 << 3;
sbi 0x0a, 3 ;i.e. DDRD |= 1 << 3;
In short, if your inputs are constants, you can use this library in
place of raw digital I/O register manipulation without worrying
about any significantly increased overhead or processing time.
Using variables as inputs can increase overhead and processing time,
but the functions in this library allow for simpler programmatic
approaches to working with digital I/O, since you no longer have to
deal with a multitude of pin-specific registers.
The digital pins on the AVR default to high-impedance inputs after
a power-up or reset.
* Written by Ben Schmidel, August 11, 2009.
* Copyright (c) 2009-2012 Pololu Corporation. For more information, see
* http://www.pololu.com
* http://forum.pololu.com
* http://www.pololu.com/docs/0J18
* You may freely modify and share this code, as long as you keep this
* notice intact (including the two links above). Licensed under the
* Creative Commons BY-SA 3.0 license:
* http://creativecommons.org/licenses/by-sa/3.0/
* Disclaimer: To the extent permitted by law, Pololu provides this work
* without any warranty. It might be defective, in which case you agree
* to be responsible for all resulting costs and damages.
#ifndef OrangutanDigital_h
#define OrangutanDigital_h
#include "../OrangutanResources/include/OrangutanModel.h"
#include <avr/io.h>
#define INPUT 0
#define OUTPUT 1
#define LOW 0
#define HIGH 1
#define TOGGLE 0xFF
#define HIGH_IMPEDANCE 0
#define PULL_UP_ENABLED 1
// port D pins
#define IO_D0 0
#define IO_D1 1
#define IO_D2 2
#define IO_D3 3
#define IO_D4 4
#define IO_D5 5
#define IO_D6 6
#define IO_D7 7
// port B pins
#define IO_B0 8
#define IO_B1 9
#define IO_B2 10
#define IO_B3 11
#define IO_B4 12
#define IO_B5 13
#if defined(_ORANGUTAN_SVP) || defined(_ORANGUTAN_X2)
#define IO_B6 14
#define IO_B7 15
// port C pins
#define IO_C0 16
#define IO_C1 17
#define IO_C2 18
#define IO_C3 19
#define IO_C4 20
#define IO_C5 21
#define IO_C6 22
#define IO_C7 23
// port A pins
#define IO_A0 31
#define IO_A1 30
#define IO_A2 29
#define IO_A3 28
#define IO_A4 27
#define IO_A5 26
#define IO_A6 25
#define IO_A7 24
#else
// port C pins
#define IO_C0 14
#define IO_C1 15
#define IO_C2 16
#define IO_C3 17
#define IO_C4 18
#define IO_C5 19
#define IO_C6 20 // only used if RESET pin is changed to be a digital I/O
#endif
struct IOStruct
// if these aren't volatile, the compiler sometimes incorrectly optimizes away operations involving these registers:
volatile unsigned char* pinRegister;
volatile unsigned char* portRegister;
volatile unsigned char* ddrRegister;
unsigned char bitmask;
#ifdef __cplusplus
class OrangutanDigital
public:
// constructor (doesn't do anything)
OrangutanDigital();
// gets a structure with pointers to the three digital I/O registers associated
// with the specified pin (DDR, PORT, and PIN) along with a bitmask with a
// 1 in the position of the specified pin and 0s everywhere else.
inline static void getIORegisters(struct IOStruct* io, unsigned char pin)
io->pinRegister = 0;
io->portRegister = 0;
io->ddrRegister = 0;
io->bitmask = 0;
if (pin < 8) // pin 0 = PD0, ..., 7 = PD7
io->pinRegister = (unsigned char*)&PIND;
io->portRegister = (unsigned char*)&PORTD;
io->ddrRegister = (unsigned char*)&DDRD;
io->bitmask = 1 << pin;
else if (pin < 16) // pin 8 = PB0, ..., 15 = PB7
io->pinRegister = (unsigned char*)&PINB;
io->portRegister = (unsigned char*)&PORTB;
io->ddrRegister = (unsigned char*)&DDRB;
io->bitmask = 1 << (pin - 8);
else if (pin < 24) // pin 16 = PC0, ..., 23 = PC7
io->pinRegister = (unsigned char*)&PINC;
io->portRegister = (unsigned char*)&PORTC;
io->ddrRegister = (unsigned char*)&DDRC;
io->bitmask = 1 << (pin - 16);
else if (pin < 32) // pin 24 = PA7, ..., 31 = PA0
io->pinRegister = (unsigned char*)&PINA;
io->portRegister = (unsigned char*)&PORTA;
io->ddrRegister = (unsigned char*)&DDRA;
io->bitmask = 1 << (31 - pin);
#else
else if (pin < 14) // pin 8 = PB0, ..., 13 = PB5 (PB6 and PB7 reserved for external clock)
else if (pin < 21) // pin 14 = PC0, ..., 19 = PC5 (PC6 is reset, PC7 doesn't exist)
io->bitmask = 1 << (pin - 14);
#endif
// low-level method for setting the data direction (i.e. input or output) of an pin or set of pins
// described by an IOStruct pointer.
inline static void setDataDirection(struct IOStruct* ioPin, unsigned char val)
if (val)
*(ioPin->ddrRegister) |= ioPin->bitmask;
else
*(ioPin->ddrRegister) &= ~ioPin->bitmask;
// low-level method for setting the PORT register value of an pin or set of pins
// described by an IOStruct pointer. If the pin is an input, this lets you choose between
// setting it as high-impedance (val = 0) or enabling the internal pull-up (val = 1). If the pin is an
// output, this lets you choose between driving low (val = 0) and driving high (val = 1).
// NOTE: if val is 0xFF (255), this method will toggle the PORT register pin(s).
inline static void setOutputValue(struct IOStruct* ioPin, unsigned char val)
if (val == 0xFF)
*(ioPin->portRegister) ^= ioPin->bitmask;
else if (val)
*(ioPin->portRegister) |= ioPin->bitmask;
else
*(ioPin->portRegister) &= ~ioPin->bitmask;
// low-level method for reading the value of the PIN register for an pin or set of pins
inline static unsigned char getInputValue(struct IOStruct* ioPin)
return *(ioPin->pinRegister) & ioPin->bitmask;
// high-level method for setting the specified pin as an output with the specified output state.
// An outputState value of 0 will cause the pin to drive low; a value of 1 will cause the pin to
// drive high. A value of 0xFF (255) will toggle the output state of the pin (i.e. high -> low and
// low -> high).
inline static void setOutput(unsigned char pin, unsigned char outputState)
struct IOStruct registers;
getIORegisters(®isters, pin);
setOutputValue(®isters, outputState);
setDataDirection(®isters, 1);
// high-level method for setting the specified pin as an input with the specified input state.
// An inputState value of 0 will cause the pin to be a high-impedance input; a value of 1 will enable the
// pin's internal pull-up resistor, which weakly pulls it to Vcc. A value of 0xFF (255) will toggle the
// input state.
inline static void setInput(unsigned char pin, unsigned char inputState)
setDataDirection(®isters, 0);
setOutputValue(®isters, inputState);
// high-level method for reading the input value of the specified pin. If the voltage on the pin is low,
// this method will return 0. Otherwise, it will return a non-zero result that depends on the value of
// the pin.
inline static unsigned char isInputHigh(unsigned char pin)
return getInputValue(®isters);
extern "C" {
#endif // __cplusplus
static inline void get_io_registers(struct IOStruct* io, unsigned char pin)
io->bitmask = 0;
#else
#endif
static inline void set_data_direction(struct IOStruct* ioPin, unsigned char val)
if (val)
else
static inline void set_digital_output_value(struct IOStruct* ioPin, unsigned char val)
if (val == 0xFF)
else if (val)
else
static inline unsigned char get_digital_input_value(struct IOStruct* ioPin)
// low -> high).
static inline void set_digital_output(unsigned char pin, unsigned char outputState)
get_io_registers(®isters, pin);
set_digital_output_value(®isters, outputState);
set_data_direction(®isters, 1);
// input state.
static inline void set_digital_input(unsigned char pin, unsigned char inputState)
set_data_direction(®isters, 0);
set_digital_output_value(®isters, inputState);
// the pin.
static inline unsigned char is_digital_input_high(unsigned char pin)
return get_digital_input_value(®isters);
#ifdef __cplusplus
#endif
#endif
// Local Variables: **
// mode: C++ **
// c-basic-offset: 4 **
// tab-width: 4 **
// indent-tabs-mode: t **
// end: **
