I have successfully integrated the 3Pi+2040 with the ROS robot operating system, but I have some concerns structuring the project for re-distribution.
To do this I forked the micro ROS implementation for the Raspberry Pi Pico and adapted it to the 3pi+ 2040. Then I added a bit of the battery reading code from the Pololu 3pi+ 2040 git repo and created a new ROS publisher. Now I can see the battery status over a ros2 topic. I wrote a blog post about that here.
I don’t know if this is the right forum to discuss this, but I’m having difficulty structuring the project in a way that I could feel comfortable re-distributing it. Rather than manually copying code over from the pololu git repo into the forked micro ROS project, I’d like a more modular approach. Furthermore, manually copying code over leaves attribution of the code in a tenuous position.
I’d prefer something like linking against the Pololu code as a library. I know that code is still in flux (Hi David!). I’d like to entreat the developers to structure that code in a way that makes linking as a library possible. If this is already possible, I ask for some hints on how to do that.
I plan to develop this out to include remote control of the 3pi+ motors using ROS2 using a Playstation controller. Eventually it might be cool to add full remote capability using a Wixel. I’ll be posting updates to my blog as I work through this problem.
Thanks,
Peter
