Dear forum,
I’m looking for the step files of Extended bracket.
My aim is to make a STEP file for my pcb Design of the couple :
10:1 Micro Metal Gearmotor HPCB 6V with 12 CPR Encoder, Side Connector
(Pololu item #: 5181)
Pololu Micro Metal Gearmotor Bracket Extended Pair
(Pololu item #: 1089)
You can download a zip file containing various 3D models of our Micro Metal Gearmotors on the motor’s product page under the “Resources” tab. It includes a couple of models with the #1089 bracket, but you will need to make some modifications to one of those models to use a motor with the assembled encoder in the proper orientation for your application.
- Patrick
hummm right but…
the right combinaison isn’t available…
i’m looking for step model of MicroMetal motor with integreted encoder AND extended braket.
That is correct; unfortunately, we do not have a model with that combination of parts. As I mentioned in my first reply, you will need to make some modifications to the models that are available to produce the specific part configuration you want with the encoder in the correct orientation.
- Patrick
