I’m using this motor driver Pololu High-Power Motor Driver 36v15
There is a !reset pin and the description on the site says “The RESET pin is pulled up to V+ through a 20 kΩ resistor. When held low, it puts the driver into a low-power sleep mode and clears any latched fault flags.”
It also says the default state is HIGH.
So should I be adding a resistor to this RESET pin myself and pull it up to V+, or does the description mean that the board itself is already pulling it up, and I don’t need to do anything?
