The Pololu site says that " The Zumo control board is essentially a shield for the A-Star 32U4 Prime, Arduino Uno or Arduino Leonardo, each of which can be plugged directly into the shield’s male header"
But my Arduino Uno R3s have a power socket that clash with the Zumo shield charge connecteor.
And is there any point in using Arduino Uno R3s as the libraries suggest you have to use an A-Star board
Can you post some pictures that demonstrate how your Arduino does not fit on the Zumo shield? Could you also post a picture of your Zumo shield that shows its identifying markings?
You should be able to use our Zumo Shield Arduino library with an Arduino Uno; you do not need an A-Star specifically. Can you link to the documentation or the part of our code makes you think you can only use an A-Star?
- Patrick
With power connector chopped off:
With power connector still on the Uno:
I can see the issue now. The Geekcreit UNO is not the same as the normal ones.
I am glad to gear you figured out the problem. Thanks for letting us know.
- Patrick
