Thanks for the response David. I appreciate the help. Yes, it is C#. Here is the full, was working in XP, code. Now in 64-bit Windows the app runs, but it’s like the Maestro isn’t getting the serial commands. I didn’t know if that was a result of the Hex values behaving differently in Windows 7 64-bit.
This app interfaces with the iRacing software API. I read the flag conditions from the API and tell the Maestro when to jump into and out of subroutines to control the LEDs. Here is a youtube video of what it is: http://www.youtube.com/watch?v=HpXlL0OYhrU&feature=plcp
Should I be able to send decimal values instead of hex? Like SP.Write(new byte[] { 167,8 }, 0, 2); Instead of SP.Write(new byte[] { 0xA7, 0x08 }, 0, 2);
I know that the flag logic is working because the console app is still running and it displays the current flag in text. The only thing that is missing is the lights changing. The console app is working as expected.
Also … I know the code is rough. I’m not a great coder. I pieced it together with the knowledge I had. Thanks again.
using System;
using System.Collections.Generic;
using System.IO.Ports;
using System.Linq;
using System.Threading;
using iRSDKSharp;
using Pololu.UsbWrapper;
using Pololu.Usc;
namespace ConsoleApplication1
class Program
static void Main(string[] args)
Begin:
Console.WriteLine("CautionLights v1.0 -- written by Steve Nuzum Jr. - " + DateTime.Now);
SerialPort SP = new SerialPort("COM4", 300, Parity.None, 8);
iRacingSDK sdk = new iRacingSDK();
string outFlag = "No Flag";
string ontrackflag = "No";
int SessionState;
int intSessionLaps;
int intMidwayLap = -99;
int SessionFlags;
string txtSessionFlags;
string hexValue;
decimal[] position = new decimal[64];
decimal[] lappct = new decimal[64];
decimal[] laps = new decimal[64];
decimal lapdistpct = Convert.ToDecimal(sdk.GetData("LapDistPct"));
int lap = Convert.ToInt16(sdk.GetData("Lap"));
decimal myposition = Convert.ToDecimal(lap) + lapdistpct;
int[] laps1 = (int[])sdk.GetData("CarIdxLap");
float[] lappct1 = (float[])sdk.GetData("CarIdxLapDistPct");
string byteSessionFlags = Convert.ToString(sdk.GetData("SessionFlags"));
int gotDataOutput = 0;
int currentSessionState = 0;
Int16 intvalue;
int newUpdate = 0;
int lastUpdate = 0;
bool ParseResult;
String ParseAttempt;
SP.Open();
while (!sdk.IsConnected())
sdk.Startup();
Thread.Sleep(10000);
while (sdk.IsConnected())
if (gotDataOutput.Equals(0))
Console.WriteLine("Track Name: " + YamlParser.Parse(sdk.GetSessionInfo(), "WeekendInfo:TrackName:"));
Console.WriteLine("Event Type: " + YamlParser.Parse(sdk.GetSessionInfo(), "WeekendInfo:EventType:"));
Console.WriteLine("Session Type: " + YamlParser.Parse(sdk.GetSessionInfo(), "SessionInfo:SessionType:"));
Console.WriteLine("Start Type: " + YamlParser.Parse(sdk.GetSessionInfo(), "WeekendInfo:WeekendOptions:StandingStart:"));
Console.WriteLine("Session ID: " + YamlParser.Parse(sdk.GetSessionInfo(), "WeekendInfo:SessionID:"));
Console.WriteLine("Sub Session ID: " + YamlParser.Parse(sdk.GetSessionInfo(), "WeekendInfo:SubSessionID:"));
gotDataOutput = 1;
if (Convert.ToInt16(sdk.GetData("Lap")) > lap)
Console.WriteLine("Lap: " + Convert.ToString(sdk.GetData("Lap")));
SessionState = Convert.ToInt16(sdk.GetData("SessionState"));
int currentSessionNumber = sdk.GetData(“SessionNum”);
if (lappct1 != null)
for (int x = 0; x < lappct1.Length; x++)
lappct[x] = Convert.ToDecimal(lappct1[x]);
if (laps1 != null)
for (int x = 0; x < laps1.Length; x++)
laps[x] = Convert.ToDecimal(laps1[x]);
if (laps != null & lappct != null)
for (int a = 0; a < 64; a++)
position[a] = laps[a] + lappct[a];
var yournumber = (from nbr in position where nbr < 1000 select nbr).Max();
int leaderpct = Array.IndexOf(position, yournumber);
bool ontrack = Convert.ToBoolean(sdk.GetData("IsOnTrack"));
//if (sdh.sessionInfoUpdate.Equals(true))
//Console.WriteLine("We should see something next, get session info");
/******* OLD GET INFO STUFF **********\
if (info == null || lap.Equals(1))
result = "0";
info = sdk.GetSessionInfo();
Console.WriteLine("Got the info");
String sessionType = YamlParser.Parse(sdk.GetSessionInfo(), "SessionInfo:SessionType:");
Console.WriteLine("SESSION TYPE:" + sessionType);
if (info == null)
start = -1;
result = "-1";
Console.WriteLine("we set the result to -1");
else
start = info.IndexOf("SessionLaps");
gotinfo = "Yes";
if (info.Length > 500)
result = info.Substring((start + 13), 3);
Console.WriteLine("We got the session info: " + Convert.ToString(result));
Console.WriteLine(sdk.GetData("SessionState"));
if (result == "unl" || result == null)
Console.WriteLine(result);
result = "-99";
intSessionLaps = 0;
Console.WriteLine("We set the result to -99");
else
intSessionLaps = Convert.ToInt32(result);
intMidwayLap = intSessionLaps / 2;
Console.WriteLine(Convert.ToString(intMidwayLap) + " - midwaylap");
Console.WriteLine(Convert.ToString(intSessionLaps) + " - Sessionlaps");
//********** NEW GET INFO STUFF ***********//
newUpdate = sdk.Header.SessionInfoUpdate;
Console.WriteLine("New Update Value: " + newUpdate);
String sessionType = YamlParser.Parse(sdk.GetSessionInfo(), "SessionInfo:Sessions:SessionNum:{0}SessionType:", currentSessionNumber);
//Console.WriteLine("Session Type: " + sessionType);
//Console.WriteLine(SessionState);
if (((currentSessionState != SessionState) & ontrack & (newUpdate != lastUpdate)) || lap.Equals(1))
lastUpdate = newUpdate;
Console.WriteLine("Session State change from: " +
Convert.ToString(currentSessionState) + " to " + Convert.ToString(SessionState));
currentSessionState = SessionState;
ParseAttempt = YamlParser.Parse(sdk.GetSessionInfo(), "SessionInfo:Sessions:SessionNum:{0}SessionLaps:", currentSessionNumber);
Console.WriteLine(ParseAttempt);
ParseResult = Int16.TryParse(ParseAttempt, out intvalue);
Console.WriteLine(ParseResult);
if (ParseResult)
// Console.WriteLine("BEAT THE PARSER");
// Console.WriteLine("Session State: " + SessionState);
intSessionLaps = Convert.ToInt16(YamlParser.Parse(sdk.GetSessionInfo(), "SessionInfo:Sessions:SessionNum:{0}SessionLaps:", currentSessionNumber));
Console.WriteLine("Midway lap: " + Convert.ToString(intMidwayLap));
Console.WriteLine("Session Laps: " + Convert.ToString(intSessionLaps));
else
Console.WriteLine("Unlimited Lap Session State");
// ********** END NEW GET INFO STUFF ********** //
if (ontrack == false & ontrackflag != "No")
SP.Write(new byte[] { 0XA7, 0x04 }, 0, 2);
Thread.Sleep(1000);
outFlag = "In Garage";
ontrackflag = "No";
Console.WriteLine("In Garage");
else if (sdk.IsConnected() & ontrack)
Thread.Sleep(750);
SessionFlags = Convert.ToInt32(sdk.GetData("SessionFlags"));
txtSessionFlags = Convert.ToString(SessionFlags);
hexValue = SessionFlags.ToString("X");
ontrackflag = "Yes";
string bit1 = "0";
string bit2 = "0";
string bit3 = "0";
string bit4 = "0";
string bit5 = "0";
string bit6 = "0";
string bit7 = "0";
string bit8 = "0";
if (hexValue.Length > 0)
bit1 = hexValue.Substring(0, 1);
if (hexValue.Length > 1)
bit2 = hexValue.Substring(1, 1);
if (hexValue.Length > 2)
bit3 = hexValue.Substring(2, 1);
if (hexValue.Length > 3)
bit4 = hexValue.Substring(3, 1);
if (hexValue.Length > 4)
bit5 = hexValue.Substring(4, 1);
if (hexValue.Length > 5)
bit6 = hexValue.Substring(5, 1);
if (hexValue.Length > 6)
bit7 = hexValue.Substring(6, 1);
if (hexValue.Length > 7)
bit8 = hexValue.Substring(7, 1);
if ((bit5.Equals("4") || bit5.Equals("8")) & (outFlag != "Caution Flag"))
outFlag = "Caution Flag";
SP.Write(new byte[] { 0xA7, 0X05 }, 0, 2);
Console.WriteLine("Caution Flag - " + Convert.ToString(lapdistpct));
else if (outFlag != "Blue Flag" & (lap > 0) & ((lapdistpct * 100) - (lappct[leaderpct] * 100) < 8) & ((lapdistpct * 100) - (lappct[leaderpct] * 100) > 0))
outFlag = "Blue Flag";
Console.WriteLine("Blue Flag - " + Convert.ToString(lapdistpct));
else if (bit8.Equals("1") & outFlag != "Checkered Flag")
outFlag = "Checkered Flag";
SP.Write(new byte[] { 0xA7, 0X03 }, 0, 2);
Console.WriteLine("Checkered Flag - " + Convert.ToString(lapdistpct));
else if (bit8.Equals("2") & outFlag != "White Flag")
outFlag = "White Flag";
SP.Write(new byte[] { 0xA7, 0X02 }, 0, 2);
Console.WriteLine("White Flag - " + Convert.ToString(lapdistpct));
else if (bit4.Equals("2") || bit4.Equals("5") & (outFlag != "Black Flag" & outFlag != "Black Flag Repair"))
outFlag = "Black Flag";
SP.Write(new byte[] { 0XA7, 0X06 }, 0, 2);
Console.WriteLine("Black Flag - " + Convert.ToString(lapdistpct));
else if (bit3.Equals("1") & (outFlag != "Black Flag Repair" & outFlag != "Black Flag"))
outFlag = "Black Flag Repair";
SP.Write(new byte[] { 0XA7, 0X09 }, 0, 2);
Console.WriteLine("Black Flag Repair - " + Convert.ToString(lapdistpct));
else if (bit8.Equals("4") & outFlag != "Green Flag Waving")
outFlag = "Green Flag Waving";
SP.Write(new byte[] { 0xA7, 0X01 }, 0, 2);
Console.WriteLine("Green Flag Waving - " + Convert.ToString(lapdistpct));
else if (bit1.Equals("1") & bit4.Equals("4") & bit3.Equals("0") & bit8.Equals("0") & (outFlag != "Green Flag") &
(bit8 != "4") & lap != intMidwayLap & (((lapdistpct * 100) - (lappct[leaderpct] * 100) > 8) || ((lapdistpct * 100) - (lappct[leaderpct] * 100) < 1))
& bit5 != ("4") & bit5 != ("8") & (lap > 0))
outFlag = "Green Flag";
SP.Write(new byte[] { 0xA7, 0X00 }, 0, 2);
Console.WriteLine("Green Flag - " + Convert.ToString(lapdistpct));
else if (outFlag != "Half Way Flag" & lap.Equals(intMidwayLap))
outFlag = "Half Way Flag";
SP.Write(new byte[] { 0xA7, 0X07 }, 0, 2);
Console.WriteLine("Half Way Flag - " + Convert.ToString(lapdistpct));
else
sdk.Startup();
Thread.Sleep(500);
SP.Write(new byte[] { 0XA4 }, 0, 1);
SP.Close();
sdk.Shutdown();
if (!sdk.IsConnected())
goto Begin;
