Oh yes I am building a 3d printer. I have a K2CNC Gantry router and, I’m putting on a Rockcliff Spider Extruder Head. I am attempting to build it as a modular accessory so I can switch to a spindle when I need a router.
What I need advise on is this, I have an MK1 heat bed and borosillicate glass for the heated bed, and for power a 12v dc 30A supply. Question, what do I need to regulate the temperature between the power supply and the bed plate?.
I know I must use 12awg wire but do I just wire it direct or is there something in between?
This question is simple but I have it on many forums and I haven’t had a response that answers the question!
Your project sounds like an interesting build. You might be able to control the heated bed with a transistor, temperature sensor, and microcontroller. The system would then be operated similarly to how a thermostat works (on when you want it warmer, and off when the platform reaches the target temperature). You might get a better discussion of this topic if you try asking on a forum dedicated to 3D printers like the RepRap forum.
- Grant
