I got a 10 pin avr programmer from avr dude kit
I need to convert it to 6 pin so , what pinout should i use in some pin out there are 3 GND on 10 pin and on some there are 4 pins for ground
Please suggest a pinout
I have made a simmiler board to sparkfun.com board , will it work ?
sparkfun.com/commerce/produc … ts_id=8508
The 3pi uses the standard AVR 6-pin ISP pinout, as listed on page 26 of the AVRISP mkII manual here, or in the 3pi schematic diagram here. Copying the SparkFun adapter board should work, but I would go by the pinouts instead to be sure.
Good luck programming!
-Adam
i am not going by sparkfun board only that was to show that type of board with connectors i have built
So it should work ?
