I started a new post to differentiate between the different projects for the 1.8" TFT display. This one focuses on the LSM303DHL Compass module from Pololu to a BabyO using Arduino code.
This sketch sets up the display to show the output from the compass. The accelerometer data for the XYZ planes is displayed in text and by a graphical bar. The accelerometer data ranges from -2048 to +2047. The bar graph is setup to convert the accel data to +/-2g. The heading is displayed in text as degrees and by a compass dial. The Arduino sketch code is posted below.
I kept some of my Serial Monitor debug code in the sketch.
I plan on mounting this to my “tank” platform and using Wixels to send the information back to my computer.
Keep having fun,
Charlie
Use this sketch to display Compass data for the LSM303DLH sold by Pololu on a 1.8" TFT
display. This sketch uses the default +/-2g setup.
ex:
int aXmin = -2048;
int aXmax = 2047;
int aYmin = -2048;
int aYmax = 2047;
int aZmin = -2048;
int aZmax = 2047;
compass.read();
int myAccX = map(compass.a.x, aXmin, aXmax, 0, 100);
int myAccY = map(compass.a.y, aYmin, aYmax, 0, 100);
int myAccZ = map(compass.a.z, aZmin, aZmax, 0, 100);
If you ran the Acc Calibration sketch, you will have +/- 1g values.
The 1g values could be helpful in making decisions in your sketch.
Todo: Add code to display the accellerometer bars
// Setup for Pololu BabyO328P
// Serial from BabyO has to be wired to the Pololu USB Programmer
// On the Arduino, PDO/PD1 is wired to the ATMEGA16U PD3(Tx)/PD2(Rx)
// Serial Pins 328P Rx/Tx = 30/31 PD0/PD1 (BabyO Header 8/9)
// Wire BabyO 8/9 to Pololu Wixel Tx/Rx - Power Wixel from the Compass 3v3 pin
// Note: Tx(9) gets wired to Rx and Rx(8) to Tx as a NULL MODEM
// Grounds should be connected as well
// Pins SCLK and MOSI are fixed in hardware, and pin 10 (or 53) must be an output.
// Using Arduino UNO Pins as they are mapped to a ATMEGA328P
// Note: MOSI PB3 is also mapped to Motor Control in the BabyO
// So Motor and SPI Usage are mutually exclusive
// Need to pick up PB3 from the BabyO ISP Header Pin 4
// Use Board: Pololu Orangutan or 3pi robot w/ ATmega328P via Programme
// Arduino 328P BabyO
// sclk and mosi are pre-defined in<SPI.h>
// #define sclk 13 // for BabyO328 use pin 13 Mapped to PB5 (Header 07)
// #define mosi 11 // for BabyO328 use pin 11 Mapped to PB3 (ISP Header Only)
#define cs 10 // for BabyO328 use pin 10 Mapped to PB2 (Header 05)
#define dc 7 // for BabyO328 use pin 07 Mapped to PD7 (Header 12)
#define rst 8 // for BabyO328 use pin 08 Mapped to PB0 (Header 03)
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// added more colors to original example
#define DKBLUE 0x0018
#define DKGREEN 0x0600
#define DKRED 0x9802
#define ORANGE 0xF400
#define CREAM 0xFF96
#define BEIGE 0xFF50
#include <ST7735.h>
#include <SPI.h>
#include <Wire.h>
#include <LSM303.h>
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
ST7735 tft = ST7735(cs, dc, rst);
// the backlight PWM is controlled indirectly by ADC7 on the BabyO
const int backlight = 9; // Digital Pin 7 PWM for backlight
int brightness = 255; // PWM for backlight Values 0 - 255
int sensorValueNew = 0;
int sensorValue7 = 0; // Backlight Control
int sensor = 0;
int xFill = 0;
// Setting the DialRadius determines the size of the dial.
// int x, y sets the position of the center of the dial.
// All parameters associated with the dial will attempt to
// locate around the dial. Making the DialRadius too large
// will push parts of text and the dial off the screen.
// Design differnt dials for compass, speed, wind direction, etc.
int DialRadius = 20;
int x = 116;
int y = 87;
// these are used to draw lines and the dial needle
double y_to = 0;
double x_to = 0;
int degree = 0;
double calcSin = 0;
double myPI = 3.14;
// variables to help draw the bars for the accell data
int aXmin = -2048;
int aXmax = 2047;
int aYmin = -2048;
int aYmax = 2047;
int aZmin = -2048;
int aZmax = 2047;
// Array used to draw the tick marks around the dial
double tickMarks[12] = {22.5, 45, 67.5, 112.5, 135, 157.5, 202.5, 225, 247.5, 292.5, 315, 337.5};
String sensorString = "0000";
LSM303 compass;
void setup() {
Serial.begin(9600); // Open the COM port
tft.initR(); // initialize a ST7735R chip
tft.writecommand(ST7735_DISPON);
analogWrite(backlight, brightness);
mainScreen();
void loop() {
getCompass();
drawNeedle(degree);
updateAcc();
updateBacklight();
delay(100);
void mainScreen (void) {
tft.setRotation(1);
tft.setTextSize(1);
tft.fillScreen(BEIGE);
tft.fillCircle(x, y, DialRadius+7, CREAM);
tft.drawCircle(x, y, DialRadius+6, BLACK);
tft.drawCircle(x, y, DialRadius+3, BLACK);
tft.fillCircle(x, y, DialRadius+1, CREAM);
// Current N, S, E, W tick marks. Will update to triangles later
tft.drawLine(x, y-DialRadius-10, x, y-DialRadius-1, RED);
tft.fillCircle(x, y-DialRadius-5, 2, RED);
tft.fillTriangle(x-3, y+DialRadius+10, x+3, y+DialRadius+10, x, y+DialRadius+1, RED);
tft.fillTriangle(x-DialRadius-10, y-3, x-DialRadius-10, y+3, x-DialRadius-1, y, RED);
tft.fillTriangle(x+DialRadius+10, y-3, x+DialRadius+10, y+3, x+DialRadius+1, y, RED);
// the center dot in the middle of the dial
tft.fillCircle(x, y, 2, BLUE);
// Text around the dial attempts to adjust to dial size
tft.setCursor(x-2, y-DialRadius-17);
tft.setTextColor(RED);
tft.print("N");
tft.setCursor(x-2, y+DialRadius+12);
tft.print("S");
tft.setCursor(x-DialRadius -17, y-3);
tft.print("W");
tft.setCursor(x+DialRadius+12, y-3);
tft.print("E");
tft.setCursor((x+((DialRadius+36)/2)), (y-((DialRadius+36)/2)));
tft.print("NE");
tft.setCursor((x+((DialRadius+30)/2)), (y+((DialRadius+30)/2)));
tft.print("SE");
tft.setCursor((x-((DialRadius+55)/2)), (y+((DialRadius+30)/2)));
tft.print("SW");
tft.setCursor((x-((DialRadius+55)/2)), (y-((DialRadius+35)/2)));
tft.print("NW");
// uses the tick marks array to draw the tick marks
dispTicks();
tft.drawRect(57, 1, 102, 10, BLACK);
tft.drawRect(57, 12, 102, 10, BLACK);
tft.drawRect(57, 23, 102, 10, BLACK);
tft.drawHorizontalLine(58, 36, 102, BLACK);
tft.drawVerticalLine(58, 34, 5, BLACK); // -2.0
tft.drawVerticalLine(71, 34, 5, BLACK); // -1.5
tft.drawVerticalLine(84, 34, 5, BLACK); // -1.0
tft.drawVerticalLine(96, 34, 5, BLACK); // -0.5
tft.drawVerticalLine(109, 34, 5, BLACK); // 0.0
tft.drawVerticalLine(122, 34, 5, BLACK); // 0.5
tft.drawVerticalLine(134, 34, 5, BLACK); // 1.0
tft.drawVerticalLine(145, 34, 5, BLACK); // 1.5
tft.drawVerticalLine(158, 34, 5, BLACK); // 2.0
tft.setTextColor(BLACK);
tft.setCursor(50,39);
tft.print("-2");
tft.setCursor(76,39);
tft.print("-1");
tft.setCursor(107,39);
tft.print("0");
tft.setCursor(132,39);
tft.print("1");
tft.setCursor(155,39);
tft.print("2");
compassSetup();
void updateBacklight (void) {
// Uses the built in POT at ADC7 to change the brightness
// Valid values for PWM is 0 to 255. analogRead can equal 0 to 1023
// so we need to convert the analogRead to a valid PWM value.
sensorValueNew = analogRead(A7);
brightness = (sensorValueNew -3) / 4;
// update the backlight brightness
sensorValue7 = sensorValueNew;
void compassSetup(void){
Wire.begin();
compass.init();
compass.enableDefault();
// Calibration values. Use the Calibrate example program to get the values for
// your compass.
compass.m_min.x = -592; compass.m_min.y = -463; compass.m_min.z = -421;
compass.m_max.x = +440; compass.m_max.y = +565; compass.m_max.z = 487;
void getCompass(void){
compass.read();
int heading = compass.heading((LSM303::vector){0,-1,0});
degree = heading;
void readCompass(void){
compass.read();
Serial.print("A ");
Serial.print("X: ");
Serial.print((int)compass.a.x);
Serial.print(" Y: ");
Serial.print((int)compass.a.y);
Serial.print(" Z: ");
Serial.print((int)compass.a.z);
Serial.print(" M ");
Serial.print((int)compass.m.x);
Serial.print((int)compass.m.y);
Serial.print((int)compass.m.z);
Serial.print(" Heading: ");
Serial.println(heading);
void drawNeedle(double _degree){
// draw or erase needle
// Erase the old needle
tft.drawLine(x + x_to, y + y_to, x, y, CREAM);
x_to = 0;
y_to = 0;
// I use our old friend from geometry, the pythagorean theorem, to draw the needle
double x_t = 0;
double calcRad = _degree * myPI / 180;
// I set this up to use in place of multiple sin(calcRad) calls, but I
// left the sin(calcRad) in for now
calcSin = sin(calcRad);
// Each quadrant around the circle has + or - values in relation to the center
// point (x, y). The sin() function returns +/- values for x_to, but y_to has
// to be manipulated.
if (degree > -1 && degree < 91)
x_to = sin(calcRad)*DialRadius;
// The x_t value was inserted for trouble shooting. May be removed later.
// Shouldn't matter because (neg * neg) = positive number.
x_t = -1 * x_to;
y_to = -1 * sqrt((DialRadius*DialRadius)-(x_t * x_t));
if (degree > 90 && degree < 181)
y_to = (sqrt((DialRadius*DialRadius)-(x_to * x_to)));
if (degree > 180 && degree < 271)
if (degree > 270 && degree < 361)
x_t = -1 * x_to;
y_to = -1*(sqrt((DialRadius*DialRadius)-(x_t * x_t)));
// update the screen data
tft.drawLine(x + x_to, y + y_to, x, y, BLUE);
tft.setCursor(2, 2);
tft.setTextColor(BLUE);
tft.print("AX:");
tft.fillRect(2, 12, 50, 8, BEIGE);
tft.setCursor(2, 12);
tft.print(compass.a.x);
tft.setCursor(2, 22);
tft.print("AY:");
tft.fillRect(2, 32, 50, 8, BEIGE);
tft.setCursor(2, 32);
tft.print(compass.a.y);
tft.setCursor(2, 42);
tft.print("AZ:");
tft.fillRect(2, 52, 50, 8, BEIGE);
tft.setCursor(2, 52);
tft.print(compass.a.z);
tft.setCursor(2, 87);
tft.print("DEGREE:");
tft.fillRect(2, 98, 60, 25, BEIGE);
tft.setTextSize(3);
tft.setCursor(4, 100);
tft.print(degree);
tft.setTextSize(1);
tft.setTextColor(WHITE);
void dispTicks(void){
// uses the tickMark[] array
for (int i = 0; i < 12; i++){
double xtick_F = 0;
double ytick_F = 0;
double xtick_T = 0;
double ytick_T = 0;
double x_t = 0;
double calcRad = tickMarks[i] * myPI / 180;
if (tickMarks[i] > -1 && tickMarks[i] < 91)
xtick_F = sin(calcRad)*(DialRadius+1);
x_t = -1 * xtick_F;
ytick_F = -1 * sqrt((DialRadius+1)*(DialRadius+1)-(x_t * x_t));
xtick_T = sin(calcRad)*(DialRadius+7);
x_t = -1 * xtick_T;
ytick_T = -1 * sqrt((DialRadius+7)*(DialRadius+7)-(x_t * x_t));
if (tickMarks[i] > 90 && tickMarks[i] < 181)
x_t = xtick_F;
ytick_F = sqrt((DialRadius+1)*(DialRadius+1)-(x_t * x_t));
x_t = xtick_T;
ytick_T = sqrt((DialRadius+7)*(DialRadius+7)-(x_t * x_t));
if (tickMarks[i] > 180 && tickMarks[i] < 271)
x_t = xtick_F;
x_t = xtick_T;
if (tickMarks[i] > 270 && tickMarks[i] < 361)
x_t = -1 * xtick_F;
x_t = -1 * xtick_T;
tft.drawLine(x + xtick_T, y + ytick_T, x + xtick_F, y + ytick_F, RED);
void updateAcc(void){
// update Accellerometer rectangles
xFill = myAccX;
tft.fillRect(58, 2, xFill, 8, DKGREEN);
tft.fillRect(58+xFill+1, 2, 100-xFill-1, 8, WHITE);
xFill = myAccY;
tft.fillRect(58, 13, xFill, 8, DKBLUE);
tft.fillRect(58+xFill+1, 13, 100-xFill-1, 8, WHITE);
xFill = myAccZ;
tft.fillRect(58, 24, xFill, 8, DKRED);
tft.fillRect(58+xFill+1, 24, 100-xFill-1, 8, WHITE);
