On reading up the ATmega docs at atmel.com/devices/atmega2560 … =documents, I worked out that channel C simply wan’t being enabled for pwm.
To correct this, we need to write a different magic number to timer control register A:
TCCR3A = 0b10101000;
This gem should allow successful running ultrasonic pwm on pins 3 & 5, which aren’t already used, so only 2 jumper wires and 2 track cuts are needed.
Thank you for the work on this. I was unable to make this work. I’m trying to use this shield and an XBee shield. I have remapped the RX/TX lines of the XBee (2,3) to (10,13) which works fine with softwareSerial. I bent the stackable header leads of 2,3,5 on the XBee out of the way. I remapped pins 11,12 to 2,5 on the motorDriver board, and bent pins 2,5 out of the way on the motorDriver board. I changed the include to be for the Mega, and placed the libraries in the Arduino library folder.
From here, I thought I’d be able to use the same commands as before (dm.setM1Speed(0)) but the motor just spins as if set to full speed. Did I miss something above?
It sounds like you did not remap the right pins for using the library given above. Could you list what each of the pins on your Arduino is connected to? Also, could you post a picture of the remapping?
Thank you for the very fast reply. Here’s the exact remapping that I did:
The motor driver shield sits on the Mega. The Xbee shield sits on the motor driver shield.
XBee shield: Bent the through stackable header pins 2,3,5 out of the way. With solid core wire, via the stackable headers, mapped pins 10,13 to pins 2,3 on the XBee shield for RX/TX using SoftwareSerial.
MotorDriver shield: Bent through stackable header pins 2,5 out of way. With solid core wire, mapped pins 11,12 to 2,5 on the motor driver shield.
So… now…
pins 2 and 5 from the MEGA do not continue up the boards at all.
pins 2,3, and 5 do not continue up from motor driver shield to xbee shield.
I thought that this was right, as based on the libraries, the motor driver shield needs pins 2,3,5 for PWM and pins 11,12 now remap for pins 2,5.
Normally, the Xbee needs pins 2,3 for RX/TX, but those are now remapped to pins 10,13.
I’ll post a photo as soon as my phone(camera) comes back online.
To use the DualVNH5019MotorShieldMega library you should connect the M1PWM and M2PWM lines from the shield to pins 11 and 12 on the Arduino and the M2EN/DIAG line to pin 5 on the Arduino. This can be done by cutting the traces going to pins 9, 10, and 12 on the bottom of the shield and soldering a wire to connect the PWM pins to pins 11 and 12 and the M2EN/DIAG pin to pin 5 on the outside edge of the shield as described in the “Remapping the Arduino Connections” section of the user’s guide.
If you are able to post a picture of your setup, I might be able to help you further.
However, please not that this modification is only for using the modified version of our VNH5019 library that is given at the top of this thread, and you do not need to use this library to use the VNH5019 shield with an Arduino Mega. This library should only be used if you want to run your motors with a 20kHz PWM to eliminate the motor noise.
Thank you for the explicit clarifications. I got a little confused by the thread but the original and these instructions make more sense and work just fine for me now. I wanted this ultrasonic PWM library so that I could remove the loudly audible PWM whine coming from my motors. I’ve just used simple H-bridge circuits in the past and there are nicely built functions to set the PWM frequency on Arduino PWM pins, but this motor driver shield is very handy and quite powerful. Thanks for the speedy and clear help. Cheers.
I’m working with the VNH5019 on a Mega 1280. I’ve found that when I set the speed to 399, I only get around 62 to 64% Duty Cycle. When I set it to 400, I get 100% Duty Cycle. What am I missing? Were did my other 40% go?
Okay. Update… I did some massive testing tonight with the Library… I changed the max PWM value to 625. I ran a looping test that count from 0 to 625. The duty cycle on my oscilloscope spike at a 100% when the counter hit 400 and 401… then resumed normal progression at 402 up through 625. I’m not sure what’s magical about the 400 and 401 values for the PWM… but, what ever the reason… those 2 numbers cause the issue… I wrote some extra code to make it skip those two numbers and my program works fine now. Anyone have ANY insight into why this may be? Where did that initial 400 value come from? I find it strange that that’s the default top PWM value and that’s the value that causes the duty cycle to spike… Could they’re be something strange with the timer values and some sort of strange relationship with 20Khz ??
Yes, I am. I was trying to figure out where the “400” came from to begin with… I couldn’t figure that out… But, like I said, at 399 it’s round 62-64% duty, 400 and 401 it spikes to 100%, 402 it picks back up at the 64-65% mark and is good all the way up till it hits 625 which is 100% duty again… What’s stranger is… I would think it would be 512 or 1024 for the top value for the PWM depending on if it was a 9 bit or 10 bit counter for the clock…
Okay, Found the problem… issues is in the following areas…
#if defined(AVR_ATmega168)|| defined(AVR_ATmega328P)
OCR1B = speed; #elseif defined(AVR_ATmega128) || defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
// Mega board specific stuff here - assumes assigning timer3, using pins 3 &5
OCR3B = speed; #else
analogWrite(_PWM2,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255 #endif
#elseif isn’t valid, it should be #elif
also, OCR3B should be OCR1B… The elseif problem is throughout the file, but the OCR3B is only on line 116.
I think it was falling through to the analogWrite part of the code… which would work correctly up to the 400 or 401 which = 255 when rounded up. analogWrite then must put the pin in a high state regardless of the PWM value… which is why it was acting strangely.
Continuing on with the math… 625 = 398, 626 & 627 = 399 and 628 & 629 = 400… Which was the cut off value I found…
So, that explains the strange behavior. Please update your libraries to reflect the bug fixes.
One think that would be nice would be a easy way to switch the motor orders… In my setup. Do to wire lengths… I had to go through and swap all the pins… and the OCR1A and OCR1B… and of course, the _PWM1 and _PWM2 have no effect with this library, as we’re not using the analogWrite function… (or shouldn’t be)
Thank you for pointing those mistakes out; I really appreciate it. You are right about it not recognizing the elseif statement and falling through to the else statement. I have tested the library with both of the changes you indicated and updated it in my original post. I also fixed the second code block in that post, which used to have the header file instead of the C++ file in it.
I wouldn’t say mistakes… I would say bugs. Bugs happen… I’m a magnet for them… Glad to have figured it out… it was driving me crazy. I thought I had a problem with my PID loop.
I would like to modify the library to disable some of the optional driver functions, like M2EN, to free up some of the PWM outputs on the MEGA. (I am new to modifying libraries).
Yes, that is the only change that you should have to make in the library to change the pin used for EN2DIAG2. However, you do not need to make any changes to the library if you use the alternate constructor documented on the libraries github page.
This constructor lets you remap pins directly from your Arduino sketch; that way you do not have to remember to modify the library every time you want to change a pin. For your particular case, you could just find the line in your sketch that creates the shield object and change it to the following:
In case you haven’t already done it, you will also have to physically disconnect the EN2DIAG2 pin from the Arduino pin it is connected to by default. You can do this by cutting the trace going to it on the shield, as shown in the Remapping the Arduino Connections section of the shield’s user’s guide. You can then rewire it to whatever pin on the Arduino you want to use.
I went to use this library and found that, while all the required info is here, I found no single source to download it from; the zip file in the first post still has the bugs that are discussed, and the github site doesn’t have the Mega-20kHz version at all (as far as I can see).
I just checked the zip file and it seemed to have the bug fixes that were mentioned earlier in this thread. From the file you posted, it does look like you somehow got an older version. Could you try downloading the zip file from the first post in this thread again?
This modified version of the library is not on our github page, because it is just modification of our original VNH5019 libraries.
