I am developing a product using 24v12 simple motor controllers.
For an added bit of safety Iโd like to use the kill switch feature on the A2 input (A1 is already used for something different).
Is there a way to activate the kill switch just using serial commands?
I know I can do this via USB, but I really donโt want to configure hundreds of boards manually that way.
There is no serial command that will configure a limit/kill switch for the Simple Motor Controller (SMC), but you can save a settings file using the Simple Motor Control Center and then apply it to each SMC. I recommend using the SmcCmd command-line utility to help automate that process.
We would be interested to hear more about your product. Please keep us posted!
