Hey all,
my 3pi came in the mail the other day. I can’t seem to program it at all through the Arduino IDE.
Detailled error log is this:
[code]avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright © 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright © 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Development\Programme\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001–0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.[/code]
Following conditions:
- 3pi is new. It arrived with a demo program loaded, which works fine.
- 3pi is powered by batteries at the time or programming (I did run a test with 3pi being powered through the programmer, same result)
- programmers are 2 different USBTinyISP devices. One commercial, one home-made. Both are known to work.
- Environment is 64bit Windows 7, IDE is Arduino IDE 1.6.6
- The add-on for the 3pi is the one linked in Programming Orangutans and the 3pi Robot from the Arduino Environment PDF - direct link to the addon
- Board selected in the ArduinoIDE is "Pololu Orangutan or 3pi robot w/ ATmega328P
- programmer selected in the ArduinoIDE is USBtinyISP
I did try to read the fuses of the chip on the 3pi after seeing
this thread on your forums - without success - by running this on the windows commandline:
the result is this:
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Development\Programme\WinAVR\bin\avrdude.conf"
Using Port : Com3
Overriding Baud Rate : 19200
AVR Part : ATMEGA328P
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
this check.
Sequence of me doing things:
- connect programmer to PC
- power up the 3pi
- connect programmer to 3pi
- attempt to write program
Some things I’ve noticed:
- when I plug in the commercial USBTiny, the LCD display gets garbled and the buzzer sounds once. Neither happens with my home-made programmer
- if I connect the programmer to the 3pi first, and then to the PC, Arduino IDE doesn’t recognize the programmer at all
Everything tested with multiple different sets of freshly charged batteries, on multiple USB ports with 2 seperate cables. With that, I’m out of ideas. Any advice?
Thanks a ton in advance.
