Commenting code out seems to add “creep” or turning a couple of degrees after stopping at each Cardinal Point, while with code in “creep” is more occasional. So, leaving code in, is better.
Going to try to inscribe a square around the center point of Zumo using Mr. Compass. Think it will work? Maybe attach a pencil to Zumo.
Hi
just to let you know my experience with this one. Downloaded and installed the sketch, the zumo span around twice, then went into a mad spin, non stop. I changed the sensitivity from 13 to 25 and it now works perfectly. (no buzzer mind you, but thats not a prob, it works with the buzzer lib so I’m not worried, probably just the pin assignment) this is with an arduino UNO so that probably explains the buzzer.
