How are you powering your servos and have you read my post to you about servo power in your programming problems thread?
There’s an easy way narrow down what the issue might be:
Run your code with only the bottom servo plugged in (i.e. unplug the top servo from your X2). Does it do what it’s supposed to when the button is pushed? This test is successful, it is an indication that you are having a power issue. The X2’s onboard voltage regulator is not really designed to power servos, especially if they are straining.
If not, unplug the bottom servo and plug in the top servo where the bottom one was. Does this servo behave as you would expect the bottom servo to behave when the button is pushed? If this test is successful, it might be an indication that you have a problem with your bottom servo.
If neither servo works well while plugged into the bottom servo’s port, then it’s possible there’s a problem with your code, but I don’t want to spend much time looking for a problem in your code until there’s a strong reason to think one might be there.
