Can I run this with a maestro? This wiper motor can run at 5 volts.
monsterguts.com/index.php?act=vi … roductId=4
Thanks
Thanks
No, the Maestro is a servo controller and cannot directly control motors like the one you mentioned. You might consider watching the video tutorial on the wiper motor’s product page to better understand how to operate it, and if you still aren’t sure, you might try contacting Monster Guts directly.
- Zeeshan
I thought you could use a channel set to PWM to control it.
You will need more than just a PWM signal to drive a motor. You should check with Monster Guts about alternative ways to control the motor.
- Zeeshan
