I’m wondering if my Mini Maestro will be able to control this motor driver?
Thanks
Cade
Thanks
Cade
Hello, Cade.
The Mini Maestro cannot control our DRV8835 dual motor driver carrier, since it requires two PWM signals to independently control the motors. It is possible to use the Mini Maestro to control our Qik 2s9v1 Dual Serial Motor Controller using a Maestro script and serial commands. You can see more about sending serial commands using the “SERIAL_SEND_BYTE” in the “Command Reference” section of the "Pololu Maestro Servo Controller User’s Guide
-Derrill
