Voltage to pwm converter
I have a small ECU that runs a RC turbine engine with a brushed dc motor for the starter, I’m looking to run a speed control for a bldc starter motor, but right now the ECU only puts out 0 to 10 volts dc, so I’m looking for something to turn that 0 to 10 volts into a pwm signal to run a brushless speed control to a brushless starter motor
Any ideas?
Just to clarify, when you say you want to turn an analog voltage signal into a “PWM signal”, do you mean a hobby RC servo signal or a duty-cycle based PWM signal?
Hi
Yes for a servo
We do not have a device with the sole intended function of converting an analog voltage signal into an RC servo signal, but you could program something like the Maestro Servo Controller or Arduino-compatible A-Star controllers to behave that way. However, please note that they are 5V devices, so you would need to run your 0-10V signal through something like a voltage divider to reduce it to an acceptable range.
Thanks for the help but that is probably beyond what i can do
