I am using the VNH5019 with an Arduino Uno. I needed the default Arduino pins for other uses so I modified the VNH5019 board as follows:
M2ED --> pin 0
M1PS --> pin 5
M2PS --> pin 6
M1ED --> pin 9
M2IA --> pin 3
I then modified DualVNH5019MotorShield.h and DualVNH5019MotorShield.cpp (code snippets below). Direction works fine but I have no control over speed. The motors always run at what appears to be max no matter what speed values I use, including zero (I don’t have a scope).
Any ideas?
private:
unsigned char _INA1;
unsigned char _INB1;
//static const unsigned char _PWM1 = 9;
static const unsigned char _PWM1 = 5;
unsigned char _EN1DIAG1;
unsigned char _CS1;
unsigned char _INA2;
unsigned char _INB2;
//static const unsigned char _PWM2 = 10;
static const unsigned char _PWM2 = 6;
unsigned char _EN2DIAG2;
unsigned char _CS2;
DualVNH5019MotorShield::DualVNH5019MotorShield()
//Pin map
_INA1 = 2;
_INB1 = 4;
//_EN1DIAG1 = 6;
_EN1DIAG1 = 9;
_CS1 = A0;
//_INA2 = 7;
_INA2 = 3;
_INB2 = 8;
//_EN2DIAG2 = 12;
_EN2DIAG2 = 0;
_CS2 = A1;
DualVNH5019MotorShield::DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
unsigned char INA2, unsigned char INB2, unsigned char EN2DIAG2, unsigned char CS2)
//Pin map
//PWM1 and PWM2 cannot be remapped because the library assumes PWM is on timer1
_INA1 = INA1;
_INB1 = INB1;
_EN1DIAG1 = EN1DIAG1;
_CS1 = CS1;
_INA2 = INA2;
_INB2 = INB2;
_EN2DIAG2 = EN2DIAG2;
_CS2 = CS2;
// Public Methods //////////////////////////////////////////////////////////////
void DualVNH5019MotorShield::init()
// Define pinMode for the pins and set the frequency for timer1.
pinMode(_INA1,OUTPUT);
pinMode(_INB1,OUTPUT);
pinMode(_PWM1,OUTPUT);
pinMode(_EN1DIAG1,INPUT);
pinMode(_CS1,INPUT);
pinMode(_INA2,OUTPUT);
pinMode(_INB2,OUTPUT);
pinMode(_PWM2,OUTPUT);
pinMode(_EN2DIAG2,INPUT);
pinMode(_CS2,INPUT);
#if defined(__AVR_ATmega168__)|| defined(__AVR_ATmega328P__)
// Timer 1 configuration
// prescaler: clockI/O / 1
// outputs enabled
// phase-correct PWM
// top of 400
// PWM frequency calculation
// 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
//TCCR1A = 0b10100000;
//TCCR1B = 0b00010001;
//ICR1 = 400;
// Use Timer 0
TCCR0A = 0b11111000;
//TCCR0B = 0b00001001;
//OCR0A = 20;
byte mode;
//mode = 0x01; 62500
//mode = 0x02; 7812.5
mode = 0x03; // 976.5625
//mode = 0x04; 244.140625
//mode = 0x05; 61.03515625
TCCR0B = TCCR0B & 0b11111000 | mode;
#endif
// Set speed for motor 1, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM1Speed(int speed)
unsigned char reverse = 0;
if (speed < 0)
speed = -speed; // Make speed a positive quantity
reverse = 1; // Preserve the direction
if (speed > 400) // Max PWM dutycycle
speed = 400;
//OCR1A = speed;
OCR0A = speed;
#else
analogWrite(_PWM1,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (reverse)
digitalWrite(_INA1,LOW);
digitalWrite(_INB1,HIGH);
else
digitalWrite(_INA1,HIGH);
digitalWrite(_INB1,LOW);
