i’ve a questions. I’m using the pololu MD03A with a DUAL VNH2SP30. So i would to read the Current output (CS) from arduino, from an analog pin.
what resistor should I use to connect the current CS pin to the arduino?
Regards
batista1987
I split your topic into a separate thread.
You should be able to connect to any of the analog pins A0 through A5. If you are trying to use our library for the VNH5019A shield, you would want to connect the 1CS to A0 and 2CS to A1.
- Ryan
Sorry, I misread your question. You do not need to use a resistor to connect the 1/2CS pins to an Arduino, you can just connect it directly.
- Ryan
