There is some potential for these types of sensors to interfere with each other when used in close proximity, but if your plan is to have sensors facing different directions, then I generally expect that to be okay, especially if you can keep each sensor outside of the field of view of the others. Ultimately though, you would probably have to test it in your particular setup to find out for sure whether it will work.
- Patrick
