I’m controlling servos on a mini maestro via matlab, I am sending each channel values from 0 to 254 but 245 only brings the servo 3/4 of the way, I cannot get the 0-254 range to correspond to the entire range of the servo, how can I accomplish this?
I am sorry you are having problems with your Maestro. Have you tried testing your servo with the Maestro Control Center software to verify that the servo can move to the position you expect? How many degrees of movement are you expecting from your servo? Can you post your settings file (as an attachment), and the bytes of the set target command? Also, can you try sending the same commands you are using in MATLAB from the Pololu Serial Transmitter utility for Windows?
-Derrill
