I am sorry if this has been discussed elsewhere and I didn’t find it. Can I use 12v in to VIN to power the the Maestro and then take the +5v regulated out to power the servo voltage VSRV?
Thank you!
The 5V regulator on the Maestro cannot supply enough current to run a servo. You can use a separate power supply that is appropriate for your servos to power the servo power rail.
-Derrill
Thank you!
