OK so I want to have a servo with a geAR TRAIN follow an IR led using a IR sensor , if the led move = follow led source , simple right ??? ( left and right is fine , I dont need up/down right now )
Ok I need suggestions on how to do this !
I have a mini Maestro and the servo motors with a gear train that will move lt/rt
I have the maestro software and can set it up fairly well including some scripts
need an IR sensor from Pololu to detect the LED
Need IR led with battery to act as the target.
need script or ?? to tell the servo controller to move lt/rt and follow the IR LED source
THanks for any input , If I missed anything please ask
We do not have any example scripts for the Maestro that move a servo based on values read from an IR sensor. You probably will have to write the code yourself. However, you might find it useful to look at this blog post, which was written by one of our engineers, on tracking movement using a Sharp Distance Sensor, a Maestro, and a servo.
Thanks , I think I can tweek that script to work with analog IR sensors ? I will order both to compare them
this is what I was looking for ( I think >? )
The Sharp distance sensors used in that project are analog, and the script compares the analog readings from the two sensors. The IR sensor products I recommended to you (in my previous post) are digital, so you will probably have to do more than just making slight modifications to that script.
