Red LED on with green flashing means that the controller thinks the serial rate is too fast. Your original post doesn’t show anything about how you’re setting the baud rate. What do you have it set to? Have you tried different speeds?
thanks your fast answer. Yes i forgot the baud rate setting. I’ve never worked with PHP and Ports before. If you or somebody have one Testscript i would be pleased to get it.
