As part of developing an obstacle avoidance strategy for my robot project which is utilizing the RP5 Robot Chassis and the Qik2s9v1 dual serial motor controller interfaced to a Netduino microcontroller and some sensors I thought it would be appropriate to understand the behavior of the RP5 when turning. The idea is to develop a table which maps a range motor speeds, as defined in the Qik2s9v1 control set, against the amount of time the RP5 should execute a turn to complete turns of 90, 180 and 270 degrees. The goal is to create a set of user callable functions to execute each of these turns where the only parameter passed is the motor speed, e.g. TurnRight90(50) - turn right 90 degrees with a motor speed of 50, and the appropriate elapsed time for the turn is taken from the table developed here. It should be mentioned that I turn the RP5 by moving one tread in the forward direction and the other in the reverse.
I have already created a class for the Qik2s9v1 which contains the basic commands for moving forward, backward, turning right and left and stopping. Below are a few lines from my “DualSerialMotorController” class which are relevant.
static byte[] stopCommand = new byte[4] { 0x8A, 0, 0x8C, 0 };
static byte[] rightCommand = new byte[4] { 0x8A, 0, 0x8E, 0 }; // Right speed passed by caller
static byte[] leftCommand = new byte[4] { 0x88, 0, 0x8C, 0 }; // Left speed passed by caller
//Stop Robot
public void Stop()
serialPort.Write(stopCommand, 0, 4);
//Turn Right
public void TurnRight(int speed)
rightCommand[1] = Byte.Parse(speed.ToString());
rightCommand[3] = rightCommand[1];
serialPort.Write(rightCommand, 0, 4);
//Turn Left
public void TurnLeft(int speed)
leftCommand[1] = Byte.Parse(speed.ToString());
leftCommand[3] = leftCommand[1];
serialPort.Write(leftCommand, 0, 4);
To determine the appropriate times for each of the three types of turns I used the “TurnRight(int speed)” and “Stop()” commands in the above “DualSerialMotorController” class and invoked them with a simple bit of code, an example of which appears below.
motorController.TurnRight(70);
Thread.Sleep(3540);
motorController.Stop();
For each speed I tested I simply adjusted the time of the “Thread.Sleep” instruction until the desired turn was completed. The testing was done on a hard wooden floor with a fresh set of batteries for the RP5 motors. Once a time was derived for a turn it was tested for repeatability. This was by no means a completely rigorous scientific experiment, for instance the RP5 can exprience tread slippage, but the data gathered is proving useful and I thought it worth sharing. I tend to use the RP5 over a speed range of 30 to 70. Below is the table with the results of my testing.
…90 Degees…180 Degrees…270 Degrees
Speed…(secs)…(secs)…(secs)
30…4.00…8.00…12.00
40…2.50…5.00…7.30
50…1.80…3.60…5.50
60…1.35…2.90…4.25
70…1.20…2.30…3.54
