I’m working with a servo controller Micro Maestro 6-channel and I can not send commands over the serial port.
I’m using vpterminal (linux) and i can’t send commands that i saw the Maestro Pololu Servo Controller User’s Guide for example:
"… For example, if channel 2 is configured as a servant and you want to set ITS target to 1500 ms (1500 × 6000 = 4 = 01011101110000 in binary), You Could Send The Following byte sequence:
in binary: 10000100, 00000010, 01110000, 00101110
in hex: 0x84, 0x02, 0x70, 0x2E
in decimal: 132, 2 112, 46
I just typed in terminal 132, 2, 112, 46 and nothing.
I can work using the master control center and is all ok, but in the terminal i do nothing.
can help me??
thanks
