Can I use one PIR sensor (Pololu item #: 1635) to trigger two Maestros? I am asking about the wiring and power concerns. I assume both Maestros will be setup in the Control Center the same way.
Thanks
Thanks
Hi.
I see no reason that your plan should not work. Following the application note guidelines, you will have to use an external pull-up resistor to keep the sensor’s output from floating. The sensor drives the output low when motion is detected.
-Derrill
