Hi, I was wondering what the voltage capacity for the TReX Jr. is. I know they can take up to 2 amps continuous, but what can it take in spikes? I need to know what size fuse to get to prevent frying the chip in the even of a spike.
Thanks
Thanks
You can find the datasheet for the MC33887 motor drivers used by the TReX Jr under the product’s resources tab. If kept cool, the IC can deliver up to a continuous 5 A. The chip has over-temperature protection, and, unlike other H-bridges, it has peak current active limiting between 5.2 and 7.8 A, which causes it to gracefully reduce current as you exceed 5 A.
- Ben
So due to the built in precautions do I even need a fuse?
It wouldn’t hurt, but you shouldn’t need a fuse.
- Ben
OK, thanks a lot.
