Cheers Adam, i saw that when i bought the vs1002 breakout board, but my worry is there is so much stuff on it, i wont know where to start!
Can i run the program on my avr that plays an mp3 file based on certain button pushes like the timings program we originally started with at the beginning of this thread? all the connections would be different and i;m not sure i wouldbe able to modify my code to these new connections. It looks quite daunting!!!
In relation to the power supply, the vs1002 breakout board needs 9v and the avr needs 3.5 so they connect to different places on my breadboard, which means i can just plug in and unplug the vs1002 board while the avr is being powered from a different place. it was a mistake when i turned the power on and the vs1002 was plugged in and the led on the dreq line didnt come onâŚ
there is no voltage from the dreq pin of avr (pin 24) to the dreq of the vs1002 breakout, but there is from pin 24 to RST, and 24 to GBUF, which are either side of DREQ. The voltage is 0.42 volts???
when the vs1002 has power the voltage from pin 24 to gnd is 0.46 volts
when the vs1002 has no power and therefore the led is on the voltage is 2.02.
does this suggest a short somwehre?
