TENET TECHNETRONICS is distributing TT-Devkit8000 evaluation boards which is equivalent to beagle
board . We also host a range of electronic boards - Micro Controller, VLSI and Embedded boards and
sensors. We host a wide range of electronic components to cater your needs. You name it we have it.
DevKit8000 Evaluation Board:
DevKit8000 Evaluation Board is a compact board using OMAP3530 microprocessor. It takes full features
of this processor and supports 128MByte DDR SDRAM and 128MByte NAND Flash as well as high-speed
USB2.0 OTG function. The board has exposed many other hardware interfaces including RS232 serial
port, LCD/TSP, DVI-D, S-Video, Ethernet, SD/MMC, keyboard, camera, SPI, I2C and JTAG. The board has
two methods to boot the system from either SD card or NAND flash. It is able to support WinCE and
Linux OS and provided with WinCE6.0 BSP and Linux2.6.28 BSP and also provides demo of Google
Android OS and Angstrom (GPE) for user experience.
TI OMAP3530 Processor based on 600MHz ARM Cortex-A8 core:
- Memory supporting 128MByte DDR SDRAM and 128MByte NAND Flash
- UART, USB OTG, Ethernet, Camera, Audio, SD/MMC, Keyboard, Jtag…
- Supports 24-bit TFT LCD/VGA, DVI-D and TV S-Video Output Display
- Supports Linux2.6 and WinCE 6.0
Features of DevKit8000 Evaluation Board :
-Processor: TI OMAP3530 microprocessor with 600MHz ARM Cortex-A8 RISC Core
-Power supply: +5V
-128MB DDR SDRAM, 166MHz
-128MB NAND Flash, 16bit
-Four buttons (Reset, Boot, User defined, On/Off)
Visit us at www.tenettech.com for more products
Contact us at info@tenettech.com for more info
Official Distributor for SPARKFUN ELECTRONICS EMARTEE and EMBEST.
