# Tamiya 'toy' motor testing
**URL:** https://forum.pololu.com/t/tamiya-toy-motor-testing/617
**Category:** Miscellaneous
**Created:** [January 10, 2008, 12:10am UTC](https://forum.pololu.com/t/tamiya-toy-motor-testing/617 "2008-01-10T00:10:50Z")
**Posts on this page:** 1
**Showing post:** 1
<div class="post-metadata">
### Author: ![nexisnet](https://forum.pololu.com/user_avatar/forum.pololu.com/nexisnet/32/19_2.png) [@nexisnet](https://forum.pololu.com/u/nexisnet)
#### Post date: [January 10, 2008, 12:10am UTC](https://forum.pololu.com/t/tamiya-toy-motor-testing/617/1 "2008-01-10T00:10:50Z")
</div>
A lot of people, myself included, are interested in just how high you can push the voltage on the motors in the small Tamiya gearboxes. I would be happy to halve the operating life of my gearbox if it means being able to run the motors faster, especially if I can run them straight from a greater-than-5V battery pack, so long as that half-life is still longer than I plan on using the motor. Lets say 20 hours of continuous operation would make me happy, and 50 would make me very happy.
Unfortunately, since these are small ‘toy’ motors, the manufacturer really doesn’t offer any cycle-life numbers, even when operating the motor at the recommended 3V or less. I happen to have a bunch of [Mabuchi FA-130](https://www.pololu.com/products/tamiya/fa_130ra.pdf)s around, those are the motors that the 70168 Double Gearbox, 70167 Single Gearbox (4-Speed), 70097 Twin-Motor Gearbox, 70093 3-Speed Crank-Axle Gearbox, 70110 4-Speed Crank-Axle Gearbox, and 70103 Universal Gearbox are based on. Recently I’ve been doing a little testing with these motors, basically I’ve been running them into the ground…in a controlled, pseudo-scientific way of course:
![](http://www-personal.umich.edu/~aborrell/orangutan/motortest/setup.jpg)
For light loading and downgearing, I’m fitting the test motors into the Solarbotics [GM9 gearbox](https://www.pololu.com/products/solbot/0188/) (143:1 reduction). The gearbox output shaft is turning a piece of card-stock which interrupts a photo-gate once per revolution. It looks like the gearbox is just sitting there, but I super-glued it to a chip socket so it presses in place on the breadboard. The photo-gate interruptions are counted by an ATTiny2313, which drives an LED display (readout in RPM) and transmits the speed readings over a serial connection to a laptop. The motors will all be driven in the same direction at a constant voltage, straight from a regulated DC power supply, working only against the internal resistance of the gearbox.
The first thing I noticed is that running the motor way over the recommended voltage makes it even more loud and annoying than these gearboxes normally are, which might be a consideration for some robots. To keep from driving myself crazy, I’m conducting these experiments with the breadboard on a piece of foam inside a (room temperature) minifridge (it REALLY helps!).
![](http://www-personal.umich.edu/~aborrell/orangutan/motortest/fridge.jpg)
The second thing I noticed about overpowering these motors was that they generate some horrendous electronic interference. The motor is powered from an isolated output of my power supply, and I added capacitors across the motor leads, but the USB-Serial adapter kept flaking out whenever I was running the motor (the LED would flicker and my laptop would stop receiving data). I even tried surrounding the adapter in grounded foil, but I eventually had to cut it out of the setup. Instead I ran the TTL serial TX line from the ATTiny through a logic inverter and into my laptop’s serial port. Neither the inverter chip nor the AVR seem affected by the interference, but still watch out (and use those capacitors!).
So far the data is less than encouraging (at least for us fans of 7.4V LiIon packs). I started out at 7.2V, the nominal voltage of a 6 cell NiMH or NiCd pack, and just under the nominal voltage of a 2 cell Lithium Ion or Lithium Polymer pack (my favorites). The motor was dead after one hour and 44 minutes. Not temporarily overheated, not slowing down, dead dead. When I took it out of the gearbox the shaft still spun freely, but it wouldn’t turn under power, even with no load, and here’s why:
![](http://www-personal.umich.edu/~aborrell/orangutan/motortest/motors.jpg)
In the picture above, the bottom motor was never used at all (sacrificed in the name of science!). The brushes and commutator (the brush-contact barrel) are pristine, shiny, and well-lubricated. The middle motor is one I had used for some amount of time, but only ran at or below 3V. There’s some grit in it, but the commutator is still smooth and the brushes are in fine shape. The top motor is the one I ran at 7.2V. There are groves maybe 20 thousandths of an inch deep on the commutator, and the brushes are seriously damaged, by which I mean that one brush is just plain gone! There is also copper dust spattered all over the inside of the casing. Less than two hours earlier this was a brand new motor, just like the bottom one in the picture. Wow.
I just finished testing another motor at 6V, which did a little better, lasting for five hours and 28 minutes. It now looks the same inside as the 7.2V motor. It’s even the same brush that’s missing (the one I had connected to power, if that makes a difference), which leads me to believe that the damage is caused by arcing, and more severe in one direction. If you run your motor in reverse some of the time it may last longer, but both brushes are damaged so it probably won’t double the life. I don’t think the ware is caused by friction directly, since the 6V motor lasted for almost three times the number of actual rotations of the 7.2V motor. Anyway, here’s the performance data I have so far:
![](http://www-personal.umich.edu/~aborrell/orangutan/motortest/chart1.jpg)
I have a 5V test running right now, and I’ve got four more motors to burn after that. I’ll keep posting results as I get them, which I can only hope will take a while!
-Adam
_[View the full topic](https://forum.pololu.com/t/tamiya-toy-motor-testing/617)._
