I have a crane that has tracks for drive. I am using a 2 stick (DX6i) radio. The left stick is boom & rotate and the right stick is hoist & crowd. I would like to flip a switch and run the drive & steer with the left stick when moving the crane. Is there a simple device I can buy to do this?
I don’t know of one. You would need the channels that are not being controlled to remember their positions when you switch your control to other channels, right?
The servos could either remember there last position or have power removed. Is there a “Y” style switch that I could use to just drop power from one set of servos while I control another?
I don’t know of a ready-made product. You could use our RC switch with small MOSFET to control a relay to give power to one set of servos or the other. However, you could get quite a bit of jerkiness when you switch since the servos could get powered up or down in the middle of a pulse.
