hello,
how to find out the supply voltage for this motor. I’ve checked the datasheet no mention about voltage supply. I’ve configurable controller that can supply 24V and 800mA current. can i use it for this motor?
You can determine the rated voltage for your stepper motor by multiplying the maximum current by the coil resistance. In this case, that comes out to 8 V. With that in mind, a 24 V supply sounds okay if you are using a controller with configurable current limiting.
-Patrick
